Hi, well i finally have my h264 avi from a MKV.
I need to convert this h264 to XVID, virtualdubb wont let me open or reencode the video because i dont have the apropiate codec installed.
VirtualDub gives me this error:
"Couldn't locate decompressor for format 'h264' (unkown)"
On virtualdubmod i can open the video, the same error jumps but i can open it, but i can only use "Direct Stream Copy" on the video menu.
Any ideas?
Closed Thread
Results 1 to 11 of 11
try ffdshow and be sure to enable h264 vfw decoding under vfw decoding options->decoder->codecs->h264->libavcodec
Great! i can open the file with no problems at all.
Now.. to be honest i have never encode with XVID, can some one point me to a good tutorial for xvid encoding? my original video file is beatufull (HQ) i wouldnt want lose any quality.
I found some guides here.. but only with 1 pass encoding.. ive heard that is better to use 2 pass right? any comments on this?
Quality is my policy.
Hi,Originally Posted by Baldrick
I installed ffdshow, but still got the message
when trying to open the *avi file with VirturldubMod.
I can't find "options->decoder->codecs-.." you mentioned. Please help.
Thanks,
Jean.
Jagabo,Originally Posted by jagabo
Thank you. Found it.
I'm trying to convert H264 to either Div or Xvid so that it can be played on standalone DVD player. Any suggestions on which format (Divx or Xvid) is better in terms of conserve the video quality?
I tried to set the same video bit rate in VirtualdubMod as the origianl H.264 one. However, it seems never work correctly. Here is what I did: video->compression->Xvid->config-> set "target bitrate"=the video bitrate in the original H.264 avi file. The converted avi has always lower bitrate than the original one-- sometime it is off quite bit.
Thank you.
Jean
Some people have a strong preference for one or the other (Xvid of Divx). I think Xvid is better but the differences are all the big.
H.264 compresses video better than Xvid or Divx. You will have to use a higher bitrate to get the same quality. Xvid may be missing your requested bitrate because the quantizer limit settings on the Xvid Configuration -> Advanced -> Quantization page. All the minimums should be set to 1, the maximums to 31. Other than that -- there were some old releases which didn't hit the requested bitrate very well.
If you don't need files of a specific size you should just use single pass target quantizer mode mode. A quantizer of 2 will give you a result that is nearly indistinguishable from your source. At three there will be a little macroblocking if you look closely at still frames (you won't notice at normal playback speeds). Higher values will give progressively lower picture quality and smaller file sizes.
i have this:Originally Posted by Baldrick
Ghost_in_the_Shell_Stand_Alone_Complex_Solid_State _Society(H264.MP3).mkv
i would like to convert h264 to xvid but it says:
"Couldn't locate decompressor for format 'ÿÿÿÿ' (unkown)"
Only Direct Stream Copy.......
i installed ffdshow and enabled h264 but i still receive the warning above...
please help.
You are in breach of the forum rules and are being issued with a formal warning. Buy Ghost on DVD. Don't dig up 3 year old topics. Convert mkv to avi xvid with alltoavi.
/ Moderator Baldrick
DVD to Xvid or H264
By hardy in forum DVD RippingReplies: 2Last Post: 10th Aug 2011, 12:35 -
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 15:13 -
XVID vs H264 on Youtube
By wrathi in forum Video Streaming DownloadingReplies: 3Last Post: 21st Feb 2011, 16:03 -
h264 to xvid
By KoRatta in forum Video ConversionReplies: 1Last Post: 5th Jun 2008, 20:36 -
MKV H264 to XVID AVI
By luca49 in forum Video ConversionReplies: 1Last Post: 11th Dec 2007, 02:35
