what is the best and cheapest unit that allows me to make copies of my DVD-RW's?
Results 1 to 18 of 18
To copy dvd-rw's all you need to do is a normal back up. Rip (or even drag and drop) video from dvd-rw to harddrive then burn using what ever burning program you have.
What We Do In Life, Echoes In Eternity.... -
Originally Posted by Denvers Dawgs
dvd burners burn dvd-rw's aslo. DVD burners burn +r/-r/rw/-rw now. So any dvd burner will work. I have a benq 1620 ($40) and have made 100+ dvds without any problems.
im looking at this site and wondering how to you even use a dvd burner? it looks like there is only 1 slot for 1 dvd or is there another slot for the other dvd on the other side?
http://www.shop4tech.com/z/DVD__Drives/3_28 -
Originally Posted by kbRenePerez
// In case there are any doubts, this is a joke.
// moderator lordsmurf -
Originally Posted by ntscuser
you can find the Benq dvd burner at www.newegg.comWhat We Do In Life, Echoes In Eternity.... -
To burn a dvd you need to
1. rip the dvd-rw to your hard drive in ISO mode, using dvddecrypter
2. Then you can Use dvddecrypter to burn the iso image to a dvd.
You will use the dvd burner (benq) for both the ripping and burning. You can only do one disc at a time.....If your stil confused keep posting, and keep reading threads...
Actually www.newegg.com only has the Benq1625 and the benq1640 now. I'd go with the Benq1640, all the reviews I have read gives it high makrs all around....What We Do In Life, Echoes In Eternity.... -
In and out, in and out, in and out, in and out, in and out.
Just like a floppy, CD, etc.
Blanks goes in, write data on it, out if comes.
If you want to copy a disc, you copy from the disc to the hard drive.
Take out the disc, put in a blank.
Write the data from the ahrd drive to the blank.
If you have two drives in proper configuration,
you can copy "on the fly" which goes from source disc to blank disc,
no hard drive needed.
This is a great burner drive:
http://www.newegg.com/Product/Product.asp?Item=N82E16827129165Want my help? Ask here! (not via PM!)
Here is a guide for backing up a dvd-rw to another dvd-r http://www.doom9.org/mpg/dvd5-backup.htm
Just in case...
I think the original poster is looking for something like this:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=92
A DVD/CD duplicator.
My guess is they are recording with a home DVD recorder onto a DVD-RW and want to make some additional copies before they erase it. They probably don't know they can use a computer for this or simply don't want to.
Then again...maybe not.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Doesnt one of the new Liteon Drives have a one touch copying thing when you push copy, put in the disc to be copied, take it and put in a dvdr? Maybe this would be easier for someone who doesnt do much with computer.
Originally Posted by Des
Yeah, after the 100th time reading this post... i think he is NOT talking about a standalone or a dvd duplicator.
But in his defense... everyone had to start somewhere at some point, it's not like we were born with the ability to know how or what to do or what we needed to do any type of dvd's 8) -
Just curious, OP, are you recording those DVD-RWs in DVD-Video mode or DVD-VR mode (where you can edit them)? If you don't know, and haven't changed the DVD recorder setting, then you're probably recording them in DVD-Video mode.
DVD-Video copied DVDs will be compatible with standalone DVD players, but DVD-VR copied DVDs won't (I think).
Region Free DVD-R Copies
By Live2WinForever in forum DVD RippingReplies: 7Last Post: 22nd Mar 2010, 14:18 -
faster way to make multiple home dvd copies
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2010, 11:37 -
Organising DVD copies on external HD?
By terrypin in forum Newbie / General discussionsReplies: 5Last Post: 1st Feb 2009, 08:43 -
Is it too much trouble to make Blu-Ray copies?
By timmus in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2009, 03:53 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 22:33
