I am new to DVD burning and would appreciate some help, I have searched elsewhere in this site but couldn't find the answer to this. I am usin Avi2dvd to convert my .avi files to DVD. Most of the time it works perfectly but occasionally when I check the conversion files before burning, the last couple will have the audio out of sync with the video. Any ideas how I can fix that? Can I split the .avi file in two and convert each half separately?
A couple of the dvd's that I burned won't play on the TV DVD. Looks like the old TV's with the verticle hold out of whack. Any thoughts?
Thanks for any help you can give me
Results 1 to 10 of 10
i have the exact same problem.. the picture doesnt go with the sound or the movie pauses near the end.. i changed a few programs and still the same problem.
my dvd burner is 2x wat about yours?
if u find the answer to this problem, please let me know. iv been trying for weeks now"Hell is empty. All the devils are here." -
This is 2 unrelated problems, I think. full_auto seems to have problems with the files, n3mi with the final DVD right?
@n3mi, it sounds like bad media. Try making your DVD a little smaller than a full DVD, like 4.2 GB, to avoid the outer edge of the disc, where bad media usually have problems.
@full_auto - sync problems are usually caused by either errors in the source avi, or a frame rate conversion gone bad. (Like the AVI is PAL, and you encode to a NTSC dvd). Also, VBR audio in the source causes trouble for many encoders.
Your last prob with "vertical hold" also sounds like a TV system/frame rate mismatch.
/Mats -
iv tried different media, still the same problem.. how do u make the dvd smaller??
Originally Posted by n3mi
/Mats -
Thanks for the info, but what's the solution? I found another program to convert the files, Super DVD Creator, which fixed the sync problem, but now all the DVD files are too large to burn onto a 4.7 g disk (which apparently is actually only 4.5 g. What happened to the other .2 gb?) and the output quality isn't as good. Man this stuff is confusing. I tried DVD shrink 3.2, which made the file smaller but when I tried to open it there was no video.
Sign me puzzled -
OK I thought I had it fixed. With the new program the out of sync problem is not as bad as before, but it is still happening. I guess what I have to do is separate the audio from the video and either stretch the audio track or shorten the video. Does anyone know of a freeware program that can do this?
Well I licked the sync problem. I set Super DVD Creator to spit the file every 150 mb and it doesn't have a chance to get out of sync. Still working on the size thing.
so worked out the problem yet??
Problems with chapters in DVD authoring/audio temporarily off-sync
By nocomments87 in forum Authoring (DVD)Replies: 7Last Post: 9th Nov 2011, 08:44 -
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 14:50 -
"fixed" AVI has audio sync and video blocking problems
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 05:00 -
audio sync problems after ripping dvd
By blubot in forum Video ConversionReplies: 4Last Post: 23rd Sep 2008, 10:14 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38
