Hy
When I go to open a movie from a folder, I always get the "explorer error" and also the "player error" in which I have to close them and I don't understand why.
When I select the movie to play I get the "Windows Explorer Error".I will attach a picture and maybe somebody will help me,please
Is it possible to be from the codecs?Which codecs are the best?give me some instructions for resolving this problem.
Results 1 to 17 of 17
File Corruption...time to reformat your hard drive and reload windows! Sorry!
Do you have this problem with all of your movies or just one in particular?
Google is your Friend -
The problem is that I have just reinstalled my windows,it is impossible to work bad.
And I have problems only with some videos,not all of them give me this error.Just some,that's why I don't know why...
Any thoughts... -
If you reinstalled your windows, you need to reinstall programs/codes, etc, before windows will properly recognize them.
Rob -
There is nothing to do to remove this problem?....
this is not the first time when I have problems like this...
Thanks anyway -
Microsoft Management Console.
Right-click on My Computer and choose Manage from the menu. Expand the Event Viewer branch, then click on Application and System in turn. Check each of these for error logs generated when you try to open a video, and see if there is anything there that might help in a diagnosis.Read my blog here.
I'm pretty confident, it's a codec problem. The explorer prob can be cured by disabling the automatic preview (a popular topic some year ago) in XP.
/Mats
PS! And try a little more describing topic - all problems around here are video related...DS
Don't remember exactly, but it just involves a little registry flag to be set/unset. Search this site, or Google.
/Mats -
Not with Explorer crashing, as soon as you select an AVI file, no. But it won't make it play any better than before. That can only be fixed by removing a bad codec/installing the right codec. I suggest latest ffdshow as an allround AVI codec.
/Mats -
Here is one approach
http://www.moviecodec.com/topics/3588p3.html
and another way of doing the same thing
http://filesoup.co.uk/forum/lofiversion/index.php/t80782.htmlRead my blog here.
MPCHC Video Audio & Video playback Problems
By skorpinok in forum Software PlayingReplies: 11Last Post: 1st Jun 2011, 10:26 -
New to video, several problems
By Tonyeng in forum Newbie / General discussionsReplies: 15Last Post: 1st May 2011, 21:02 -
Video playback problems after installing video editing suite - Please help!
By abeelandig in forum Software PlayingReplies: 2Last Post: 5th Aug 2010, 21:54 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Horizontal offset problems with video fields in video to DVD transfers
By aussiebloke in forum RestorationReplies: 3Last Post: 15th Feb 2010, 05:33
