    Apr 2005
    Montreal, Canada
    Since I converted external hard drive to NTFS from FAT32, every time I try to delete a file or folder an error message pops up. It says:
    Error Deleting File or Folder
    Cannot delete folder. Cannot find the specific path.
    Make sure you specify the correct path.
    Darn computer always telling me what to do . Any idea what I can do to delete files or folders? Only started happening when i converted to NTFS. It won't delete any files or folders if I created them before the conversion or after.
  2. Member Prot's Avatar
    Dec 2003
    Oregon
    Is this happening only when you try to delete, or does it happen even when you are accessing the folder/file? You don't mention it, but could you delete folders/files before you converted to NTFS?
    Make sure these are not read-only.
    Unplug the USB/Firewire connection. Make sure Windows is not seeing the drive, then reconnect the drive. Rebooting is recommended, but probably not necessary before you reconnect the drive.
    After Windows reloads drivers, try to delete the files again.
    TANSTAAFL
    Apr 2005
    Montreal, Canada
    It's finally deleting files and folders! Unplugging usb connection, rebooting, then plugging usb connection in worked. Thanks a lot!
    Sep 2003
    west yorkshire England
    i have had this a few times in xp go to views in the folder and change it to lists reboot and you can delet it now
