hi i make DVD video(MPEG 1 and audio 48khz) with TMPEG DVD author and i convert 5,6 Dat files to MPEG 1 352x240 29,97 fps (4:3) NTSC 1152kbps and change audio to 48 khz 224kbps and it works but
the quality of the movie still good(colour not really sharp) but not good as VCD ?
Any one now how to make it much better?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator offline
Closed Thread
If you've done nothing more than extracted the mpg out of the dat, and resampled audio to 48 kHz, then authored, there's no reason for any visual differences compared to playing the original VCD.
/Mats
You mean better than your iriginals? Not really. If your results are degraded form the originals, then maybe yes.
I work strictly from original source shot by me and not MPG1 basically VCD quality video. It is inherently already low in quality to begin with.No DVD can withstand the power of DVDShrink along with AnyDVD!
How to create video DVD from DAT file
By abhishekm in forum Authoring (DVD)Replies: 2Last Post: 20th Sep 2011, 13:28 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
Whats the best format for good video quality with reasonable file size
By hasanali00 in forum ffmpegX general discussionReplies: 2Last Post: 20th Feb 2010, 21:29 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
6 hours of good quality video on dvd
By gameroftheuk in forum Authoring (DVD)Replies: 1Last Post: 30th Aug 2007, 01:59
