hi,
i have a Premier DV2010 mpeg4 digital camera, which recoreds ASF files
this there any way i can make a file from AVI or MPEG2 that will play on
camera.
thanks.
https://www.videohelp.com/tools?tool=Virtualdub_1.4c-ASF should open ASF. You could then re-encode to AVI or frameserve to your favorite MPEG encoder.
FWIW I seem to recall that I read that the latest version of virtualdub reinstated support for ASF. I cannot find where I read that, but it just sticks in my mind for some reason.
You may be able to use AVISynth also.If in doubt, Google it. -
latest version of virtualdubmpeg2 supports asf,wmv(experimental).
Wrong way around though. They want to convert to ASF to play on the camera not from it right?
ffmpeg can output ASF and supports MPEG-4. Problem is that the camera doesn't use ISO MPEG-4 I don't think. Still ffmpeg might be ok, otherwise try Windows Media Encoder.
I really wouldn't call MS MPEG4 in an ASF container MPEG-4.
Convert Webcam Video for TV - uncompressed avi > asf > mov - best solution?
By nakedgun in forum Video ConversionReplies: 0Last Post: 17th Nov 2011, 06:41 -
Problem for cut asf with H264 video
By youtpout978 in forum EditingReplies: 2Last Post: 5th Nov 2010, 09:17 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 12:01 -
How to convert .asf video file
By peter762033 in forum Newbie / General discussionsReplies: 6Last Post: 21st Mar 2010, 11:29 -
lightening up an asf video from a camcorder
By jackie3 in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2010, 21:37
