Hi there
Usually I extract the audio from popular avis with virtualdub, full processing/compression ac3/save wav etc... This removes the problem of out of sync audio when encoding with TMPG to a dvd file so I can watch it on my tv.
Lately more and more files I acquire are using this format and I have searched everywhere for a means to extract audio from the files the way I used to with virtualdub, I always get a codec not available message even though I have every codec under the sun.
I have loaded the file in numerous codec programs and these TCM files appear to need the following
Audio
Codec Required - MPEG-1 Layer 3 (MP3)
Code - 85
Video
Codec required - Xvid MPEG-4
FOURCC - XVID
Now I have zero problems with other xvid files when ripping audio with virtualdub to a wav file, I know I have the required codecs so im assuming audio cant be taken with virtualdub on these files.
The only possible way I see to get around it at the moment is really a bother and a waste of cds
I convert the file to a vcd with nero, the only program I have seen that can convert these files so far, somehow it manages to do it, then burn on a cd and watch, but I prefer to put 5 episodes on a dvd rewritable the way I used too.
Anyway with that all being said, can you suggest any programs that may be able to extract the audio from these files into a wav file to use in TMPG encoder ? The ones I have tried so far havent been succesful.
Thanks alot
I have a problem with mp4 files in virtualdub, slow motion audio.
By barbur in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2012, 13:16 -
Problem extracting audio from WMV files
By Bully9 in forum AudioReplies: 33Last Post: 21st Jul 2011, 05:27 -
Problem Extracting files over 4gb
By PSS2 in forum Software PlayingReplies: 5Last Post: 4th Apr 2010, 20:27 -
Extracting Audio from M2TS Files
By foochuck in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 31st Mar 2010, 17:30 -
Extracting audio with VirtualDub
By RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 19:03
