Hello, i use WinTv 150 to capture and it works great,
i been capturing audio from the local radio station using this
card. The problem is that is being capture as a video file, then
i have to extract the audio out. Is there anything i can use to capture
the audio without having to go through the process of extracting the audio
from the file...i just want to save it as a .wav or mp3.
thanks!
Total Recorder has a built-in scheduler that you can use to record at a certain time and save the file. This would probably be what you are looking for.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Capture Lossless with WinTV-PVR-150
By rudolf016 in forum Capturing and VCRReplies: 50Last Post: 28th Feb 2012, 12:39 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppauge WinTV PVR-150 ($60) vs. ATI TV Tuner 650 ($100)
By RoganSarine in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2007, 03:48 -
Color Bleed on Hauppage WinTV-PVR 150
By TheBladeRoden in forum Capturing and VCRReplies: 3Last Post: 14th Jun 2007, 10:05
