    Jan 2004
    huntersvile, nc
    hey all,
    does anyone know of a feeware program that will let you take a mpg file and convert it into .mov?
    thanks for any replies,
    schunn99
    intermediate encoder
    Dec 2004
    Australia
    ffmpeg. mov is just a container though. Were there any particular codecs that you wanted to use?
    Jan 2004
    huntersvile, nc
    yeah, probably h.264, if I can find a codec for it.
    thanks,
    schunn99
    Dec 2004
    Australia
    ffmpeg includes x264 (if enabled at compile). I wouldn't use mov as a container though. Go with mp4, it plays fine with QT*. For AVC mp4's though I would suggest using the x264 commandline app. Check out MeGUI.
    *QT doesn't support HP AVC, he aac, ttext, etc. Although there was just a new version released.
