  1. 1. ATI MMC Captured, Authored in TDA = Outta Sync
    Well I followed the guide on digitalfaq and setup everything like instructed including the 4:2 ratio that was suggested if I'm using TDA anyways files are insync on the comp but when I author it with TDA and play it in the player it goes out of sync, in TDA I chose the reencode audio output.... to yeah whatever that option is when you load the file.
    2. I have some avi-mpg file, they're in sync on the comp but outta sync in the player. These are NOT captured files. Same thing using TDA to author, tried both using the reencode and without using the reencode audio option and both dvds are outta sync.
    Don't let TDA re-encode your audio.
  3. tried that too and still outta sync.
