how do i fix this i throw in any other type of dics and reads fine...
its a philips +- dvd 8631
firmware version gd30
says i can write to any of the types of dvd's was working fine havent had computer for more than 4 months drive cant be bad can it? it still picks up cd's and media fine, just when i try to werite something it acts up
Closed Thread
No need to double post. Google philips+dvd8631
This drive has issues that are both software (Sonic) and hardware related. Try a re-boot before burning. Uninstall, then re-install Sonic. Install the latest version of Nero www.ahead.de and see if it will recognize the disc. Are the problem??? discs DVD+R or DVD-R? Some have had trouble with this drive burning DVD-R media - none with DVD-R.
You may have a warranty issue after checking the re-boot and software issues out.
I worked for 9 months with a problematic Plextor drive - in the end a firmware update fixed everything. Yes, the tech support guys had me uninstalling and re-installing burning software, etc.. The funny thing was, I told them I suspected the drive's firmware was the problem - since I had another burner in the machine that burned the same media without a hitch. After the firmware update, I pulled "bad" media out and was able to get a full burn without an issue.
Don't double post. One is enough.
https://www.videohelp.com/forum/viewtopic.php?t=281786Want my help? Ask here! (not via PM!)
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2011, 04:11 -
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
DVD drive stopped reading DVDs for a very random reason..
By narutoball in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Oct 2008, 16:23 -
DVD Drive Freeze on certain discs (Different brands)
By Myrdek in forum DVD & Blu-ray WritersReplies: 10Last Post: 4th Aug 2007, 15:59 -
Can any DVD drive read DVD DL discs?
By alegator in forum ComputerReplies: 3Last Post: 5th May 2007, 21:45
