but will read cd-r's fine this is really upsettin me, how do i fix this
Closed Thread
Are you only having trouble with +/-r discs or also with pressed discs? If the drive won't read any discs, then your drive is most likely dead. Keep in mind that different lasers are used for CD's and DVD's, it is quite possible for one to work and not the other.
Google is your Friend
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2011, 04:11 -
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
DVD drive stopped reading DVDs for a very random reason..
By narutoball in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Oct 2008, 16:23 -
DVD Drive Freeze on certain discs (Different brands)
By Myrdek in forum DVD & Blu-ray WritersReplies: 10Last Post: 4th Aug 2007, 15:59 -
Can any DVD drive read DVD DL discs?
By alegator in forum ComputerReplies: 3Last Post: 5th May 2007, 21:45
