HI,
Got some films I am trying to convert from avi to Mpeg4. Have done it from my DVD's to Pmeg4 with perfect play back but AVI films on my laptop I am trying to convert always NEVER match up.
The sync isnt right with video and soundIs there a way to sync the converted mpeg4 file. Starts off fine but gradually gets worse and worse. Anyone use any other convertor and compression program to change avi to mpeg4???
Thanks in advance
what tool are you using now?
you can try convert the audio to wav with virtualdub,
video->direct stream copy(copy video)
audio->full processing (to wav)
file->save avi.
and use that avi in your converting tool. -
the converting tool is X-OOM movies to PSP.
It does a film automatically, doesnt allow you to supply different files for vids and sound.
AVI to PSP
By pugvader in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2009, 09:35 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 11:59 -
Easy GUI Conversion from Avi 2 MP4 for your video iPod or PSP
By qwerty9876543 in forum LinuxReplies: 2Last Post: 3rd Feb 2008, 11:17 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 09:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 15:13
