Sorry if this is rather newbie, I'm still learning somewhat.
I have a Japanese DVD, and I've been trying to add subtitles to this using this guide http://t2.technion.ac.il/~seranmiz/dvd_guides/Adding_Subtitles_to_DVD.htm
I've got the subtitles sorted and working perfectly, that's not the issue.
The problem I have now is that there are no longer chapters on the film. This is pretty annoying, as it breaks the Chapter menu and just makes it feel rather rough to me. I am assuming I can extract the chapter information from the VIDEO_TS.IFO on my original disc and 'patch' this information to my new one... can't figure out how to do this though!
Any helps is appriciated![]()
Results 1 to 11 of 11
Well, I think that dvddecrypter is doing exactly this - looking for the times of chapter breaks in the ifo file.
You can give a try to ChapterXtractor, but you need to configure it to give you the frame numbers (not the time) for muxman. Then save this to a .txt file and import it in muxman at authoring stage. -
If you choose the IFOEdit Preset in ChapterXtractor it gives you the frame numbers.
If in doubt, Google it. -
Erhm, there isn't Ifoedit preset by default
Code:[Presets] Preset 1=Micro DVD Player Format 1=%c=%f Chapter %c\n Header 1=[CHAPTERS]\n Footer 1= Preset 2=SVCD (hh:mm:ss:cc) Format 2=Chapter %c = %hh:%mm:%ss:%cc\n Header 2= Footer 2= Preset 3=BSPlayer Format 3=%c=%hh:%mm:%ss Chapter %c\n Header 3=[ChaptersX]\n Footer 3= Preset 4=DVDMaestro Format 4=%hh:%mm:%ss:%ff\n Header 4=$Spruce_IFrame_List\n\n Footer 4= Preset 5=OGG Format 5=CHAPTER%C=%hh:%mm:%ss.%ms\nCHAPTER%CNAME=Chapter %c\n Header 5= Footer 5= Preset 6=BeSplit parameter Format 6=%asf%sp Header 6=BeSplit -core( -input "%file" -prefix "%dir" -logfile logfile.txt -type ac3 -ending ) -split(%sp Footer 6=) Preset 7=Preset 7 Format 7=Format 7 Header 7=Header 7 Footer 7=Footer 7 Preset 8=Preset 8 Format 8=Format 8 Header 8=Header 8 Footer 8=Footer 8 Preset 9=Preset 9 Format 9=Format 9 Header 9=Header 9 Footer 9=Footer 9 Preset 10=Preset 10 Format 10=Format 10 Header 10=Header 10 Footer 10=Footer 10 [Options]
That's weird ..... I've got:
Code:[Presets] Preset 1=IfoEdit Format 1=%f\n Header 1= Footer 1= Preset 2= Format 2= Header 2= Footer 2= Preset 3= Format 3= Header 3= Footer 3= Preset 4= Format 4= Header 4= Footer 4= Preset 5= Format 5= Header 5= Footer 5= Preset 6= Format 6= Header 6= Footer 6= Preset 7= Format 7= Header 7= Footer 7= Preset 8= Format 8= Header 8= Footer 8= Preset 9= Format 9= Header 9= Footer 9= Preset 10= Format 10= Header 10= Footer 10= [Options]
I am using version 0.962 (which is probably an old version) though ...If in doubt, Google it. -
Where you get from your version?
I am looking at the same version 0.962, got it immediately before my post from the post link (I am not at my comp currently) -
I would have assumed that I got it from the tools section here. It would have been a while ago, though.
EDIT:
Actually, I lie. I grabbed it from an install of EazyVCD that I had. I'd say that Rob Ferguson must have customised the presets. Or I did for use with a few home programming projects ..... gosh darn it, now I'm all confused
How's about the best of both worlds ?
chapterxtractor_ini.zip
Code:[Presets] Preset 1=IfoEdit Format 1=%f\n Header 1= Footer 1= Preset 2=SVCD (hh:mm:ss:cc) Format 2=Chapter %c = %hh:%mm:%ss:%cc\n Header 2= Footer 2= Preset 3=BSPlayer Format 3=%c=%hh:%mm:%ss Chapter %c\n Header 3=[ChaptersX]\n Footer 3= Preset 4=DVDMaestro Format 4=%hh:%mm:%ss:%ff\n Header 4=$Spruce_IFrame_List\n\n Footer 4= Preset 5=OGG Format 5=CHAPTER%C=%hh:%mm:%ss.%ms\nCHAPTER%CNAME=Chapter %c\n Header 5= Footer 5= Preset 6=BeSplit parameter Format 6=%asf%sp Header 6=BeSplit -core( -input "%file" -prefix "%dir" -logfile logfile.txt -type ac3 -ending ) -split(%sp Footer 6=) Preset 7=Micro DVD Player Format 7=%c=%f Chapter %c\n Header 7=[CHAPTERS]\n Footer 7= Preset 8= Format 8= Header 8= Footer 8= Preset 9= Format 9= Header 9= Footer 9= Preset 10= Format 10= Header 10= Footer 10= [Options]
Is there a tool to extract chapter data and timecodes from m4v files?
By ihudson in forum EditingReplies: 3Last Post: 27th Oct 2012, 13:17 -
Can you convert a VOB file and keep chapter information?
By woody777 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 5th Mar 2010, 15:38 -
VOB2MPG Chapter Extract as Text File?
By ron spencer in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 12th Sep 2009, 17:01 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51 -
VOB to MPEG2 with Chapter Information
By badgerbrian in forum Newbie / General discussionsReplies: 1Last Post: 4th Feb 2008, 15:11
