  1. I've just bought 100 90 min CDs made by DST (www.dst.com.tw).
    The problem is that CD-RW says that CD is not in drive! I tried 3 different drives, but no luck. I've tried both sides, so no mistake was done here.
    Drives are:
    Philips 1208
    LG 8080B (supports everything)
    noname 8x4x32
    Any ideas?
  2. Rookie,
    I'm not so sure what the problem is but I heard before that if you want to use the 90 or 100 min. The drive itself must support it and must be turned on. Most drives are default as 80 min max. Try to check if there is such option. Jordan
    Nov 2000
    Houston, TX US
    LG 8080B
    Is the one you wnat to keep.
    To be able to burn 99 min CDs you have to use CDRWIN 3.8 or higher.
    But first you have to create the image file with a differnt CDR software and convert it with cue and bin with CDMAGE beta version.
    Catman
  4. Thanks to everybody,
    I've got it to work on LG. The solution was to switch off antivirus plugin (?) in Nero preferences. Then everything went smoothly and I created 91 minute CD.
    Strangely, it couldn't be read in Philips, only in LG and Toshiba CD-ROM.
  5. Give http://www.cd-mate.com a try the software supports 120 min cdr/w and more writers than you can imagine!
