Hi evryone got a prob with playback on dvd player with silver printable dvd-r (ritek G05), after burning some will play ok some I get disc error (using nero) any ideas please..........
mickdee259.............
Nero can be a bit of a git at times. Try burning with DVD Decryptor. It will only burn .ISO files so either set your software to produce an ISO rather than individual files or use Img Tools Classic to produce an ISO (both freeware). Make sure you set DVD Decryptor to verify the burn and it may be worth burning slightly slower (4x rather than 8x)
You don't say exactly what the problem is. Stuttering/pixelating right from the beginning, near the end, or what ?
I would say its not Nero the problem, rather the Riteks which were well known to crap out. -
Hello cyflyer the main problem is that sometimes when a disc is inserted into player, after loading the screen goes blank with the message disc error,then after burning something else it works perfect.....
mickdee259
Ok, I would suggest firstly, after burning check if the burn actually happened on the disc each time. I somtimes burn with Nero, it appears to have burned, but when I take the disc out and look at the dye side, its still blank. I repeat all over again, and then its ok. Still haven't figured out why it does that. If you try to play the disc you thought was burned, 'disc error' of course. If that is not the problem, try better brand of discs and see if that works.
Playback problems
By erica12 in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2012, 19:33 -
VHS-C playback problems
By kicsrick in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2009, 12:43 -
mkv playback problems
By sumarIII in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 17:01 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
Playback problems
By Dick Stilton in forum Newbie / General discussionsReplies: 4Last Post: 26th Aug 2007, 07:21
cheers will try it out
