I'd like to burn a DVD-R of instructional DVD segments (2 segments, each 3 minutes long) but I'd like it to be looped continuously without anybody needing to get up to the DVD player to press play over and over again.
Is there an easy and cheap way to do this? I'm doing this as a volunteer work so the budget is zero (or very close to it).
The current programs I currently use are DVD Shrink, AnyDVD and DVD Decrypter. I don't think any of those will enable me to create a continuous loop.
Any helpp will be appreciated.
Thanks.
many authoring tools support looping like tmpgenc dvd author, https://www.videohelp.com/forum/viewtopic.php?t=232584&highlight=tmpgenc+loop
or search for loop in this forum. -
Thanks for the help, however, as mentioned, I'm doing this as a volunteer work and I'm unwilling to spend US$70 for a software that's going to be used once for absolutely zero profit. Is there a freeware out there that can do this?
"Half empty or half full, it's still only half a glass" - What Dave Says -
Originally Posted by sapiendut
http://www.pegasys-inc.com/en/download/tda16.html -
The guide for looping is here:
https://www.videohelp.com/~gfd/GUI_DVDauthor_eng_07.htm#Autorepeating_DVD
If you like to use GfD, you should read the rest of the docu too...GUI for dvdauthor:
Dvd with looping chapters...
By miksterr in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2010, 00:23 -
Creating a continuous looping DVD playlist from hard drive
By bryners in forum Software PlayingReplies: 4Last Post: 6th Apr 2010, 14:49 -
Specific looping?
By Koron in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2008, 16:32 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
Looping DVD with no menu
By SCDVD in forum Authoring (DVD)Replies: 7Last Post: 21st Feb 2008, 20:12
