how do i fix this i throw in any other type of dics and reads fine...
What about DVD-Rom? or DVD-Ram? Does it read either of those fine? Which drive model?
My old Lite-on DVCD-Rom could not read +R discs -R it was fine with I think the Nero Info Tool can read your drives firmware and report what sort of discs it can read
HTH -
Do you mean that you can read CDs or other types of DVD Media? Can it read comercial DVDs?how do i fix this i throw in any other type of dics and reads fine...
If you can no longer read DVDs but still can read CDs then more than likely your DVD laser is dead.
It happened to me from one disc to the next. No warning whatsoever!No DVD can withstand the power of DVDShrink along with AnyDVD! -
sorry for other topic was mistake its a philips +- dvd 8631
firmware version gd30
says i can write to any of the types of dvd's was working fine havent had computer for more than 4 months drive cant be bad can it? it still picks up cd's and media fine, just when i try to werite something it acts up -
CD's and DVD's are totally seperate. Does the drive read pressed/commercial discs (like movies)? If it doesn't then your drive is likely dead.
Google is your Friend
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2011, 04:11 -
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
DVD drive stopped reading DVDs for a very random reason..
By narutoball in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Oct 2008, 16:23 -
DVD Drive Freeze on certain discs (Different brands)
By Myrdek in forum DVD & Blu-ray WritersReplies: 10Last Post: 4th Aug 2007, 15:59 -
Can any DVD drive read DVD DL discs?
By alegator in forum ComputerReplies: 3Last Post: 5th May 2007, 21:45
