Hi
I have lots of short clips I have encoded into .m2v & .wav to author using TMPGenc, eventually ending up with loads of clips I can put onto a DVD.
The thing is, when I author each separate clip, surely I will get the same ifo / vob filenames? Will just dragging & dropping these using Nero cause a problem, and will I keep getting "overwrite same file name" problems?
How do I author the 20 or so clips to go onto one dvd, without joining them, and have each clip as a new chapter?
If anyone can help, I'd really appreciate it.
Cheers,
Ian
No need to 'author' each clip. Use TDA. Add 1st file with separate video and audio if that's how you have them and then just 'add new track' for 2nd file and so on. Create menu relative for the no. of tracks/files you've added and when outputted, it will create just the one TS folder for burning.
Thank you both very much! It sems to have worked, just got to see which clips are rubbish now! Thank you for the help
Disagree with jimmalenko as to creating one large file. I would add them separately and then create a 'Loop' within TDA if you want continuous playback of all tracks. The benefit of that is that you have all tracks as thumbnails and you can select tracks at will as opposed to going through and selecting different chapter points for the song you want to play.
The good thing about the forum is that you may get differing views and you go with the one which is best for you and NOT me!!!! You now have 2 options, 1 from me and 1 from Jimmalenko-try it out and go with what suits you!! -
Agreed it is. I think i pretty much steered him in right direction at beginning of thread. I only differed from your previous comment when you mentioned 'Continuous' playback that's all. Just thought it more convenient if tracks were 'looped'. Then again, he never asked that in the beginning, so i think we may both have digressed slightly. Based on what we've posted, I think he's cracked it anyway which is great. What the hell, thank **** it's friday!!!! Enjoy the weekend.
Capture Short Video Clips From 1.5 Hour DVD
By Grassman in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2012, 01:52 -
Need to record short vid clips from DVD's...Best method?
By BlueProteus in forum Capturing and VCRReplies: 15Last Post: 11th Dec 2011, 11:47 -
Lots of fast pictures and video clips
By ChEeZeBaLL in forum EditingReplies: 2Last Post: 18th Jul 2010, 03:06 -
Simple tool to make video from photos and short clips?
By largactyl in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2008, 12:45 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 16:43
