I am watching a japanese movie, with japanese language and english subtitles, and ths ubtitles are difficult to read.
I am using media player classic 6.4.8.2 and I know there are settings for SUBTITLES however they seem to have no effect on DVD subtitles? when I play a DVD and try to adjust the size/ font/ color of the subtitles the settings have no effect on the subtitles I see on the screen
Is it possible to adjust the subtitles for a DVD, and if so how? (and before I'm asked, yes I did verify these are removable subtitles and not part of the actual video)
Patrick
Shuttle SH55-J2-BK-V1 w/4.00gb Ram, INTEL i3-550, 3.2ghz, WIN7 home premium 64bit
hauppauge 950q, 1600, 1250 -
DVD subtitles are bitmaps, therefor you can't change the font, etc. Colours you should be able to change. If you want full control, you need to convert to text.
so on any "store-bought" DVD there is no way to change the size/font of subtitles? I would assume then that the subtitle options within Media Player Classic are only for subtitles/subtitle files that might be associated with an AVI file?
text subtitles. meaning any subtitles that are provided as separate files as in the case of select MPG/AVI videos? which would NOT include "store-bought" DVDs with subtitles, whihc would be "un-alterable"
No ANY text subtitles, external or internal. Regular DVD subtitles as I said use bitmaps. If MPC's subtitle render supports CC's and a DVD had them then you would be able to change the font, etc. for them.
Also, just because a sub is external doesn't mean that you can control the font, etc. since they could be VOBSub's, in which case once again they are bitmap based.
Media Player Classic - Home Cinema Settings Help
By ACiDxCHRiST in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2011, 23:29 -
Media player classic - loading subtitles
By jujuandhuhu in forum Software PlayingReplies: 5Last Post: 19th Dec 2008, 09:26 -
Changing Media player Classic background
By punisa in forum Software PlayingReplies: 9Last Post: 27th Sep 2008, 08:29 -
subtitles not showing up on media player classic
By cdcmoon in forum SubtitleReplies: 1Last Post: 1st Nov 2007, 03:06 -
Media Player Classic + SRT Subtitles
By Basketbits in forum SubtitleReplies: 3Last Post: 17th Jul 2007, 03:53
