I just gave it a try and it immediately failed. Here is the log:
Encoding started on Wed Oct 12 16:34:02 PDT 2005
MEncoder dev-CVS-050123-19:55-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0xd0ea736
ISO: Unknown File Type Major Brand: M4V
QuickTime/MOV file format detected.
MOV track #0: 12443 chunks, 112472 samples
Audio bits: 16 chans: 2 rate: 44100
MOV: Found MPEG4 audio Elementary Stream Descriptor atom (51)!
Fourcc: smrd
MOV track #1: 10447 chunks, 62679 samples
MOV: AVC decoder configuration record atom (45)!
MOV: Found unknown movie atom sinf (924)!
Image size: 320 x 240 (24 bpp)
Display size: 320 x 240
Fourcc: imrd Codec: ''
MOV: longest streams: A: #0 (112472 samples) V: #1 (62679 samples)
Cannot find codec for audio format 0x736D7264.
VIDEO: [imrd] 320x240 24bpp 24.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x696D7264 size:320x240 fps:24.00 ftime:=0.0417
Read DOCS/HTML/en/codecs.html!
Opening video filter: [expand osd=1]
Cannot find codec matching selected -vo and video format 0x696D7264.
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale w=320 h=240]
Exiting...
Download/Capture trailers from Itunes store?
By digitalfreaknyc in forum Video Streaming DownloadingReplies: 24Last Post: 14th Oct 2020, 15:42 -
Converting ITunes protected video to AVI for DVD
By jessejames in forum Video ConversionReplies: 5Last Post: 12th Jun 2010, 18:25 -
converting files for iTunes
By Janik in forum Blu-ray RippingReplies: 2Last Post: 5th Jan 2009, 20:31 -
Question about "legally" converting itunes drm video
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th Nov 2008, 11:12 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 01:17
