I have made several movies before using Ifoedit with subtitles and have had no problems. I copied the DVD to my computer using DVD Decrypter IFO mode. Then demux the streams. Ripped the subtitles to .srt. Used srt2sup to convert them. I input the video, audio and subtitles into Ifoedit and then authored the DVD. The subtitles came out green as always. I copied the colors from the original DVD and pasted them to the new project. Saved the changes. Opened with Windvd and the subtitles are black now. Tried copying the colors from other DVDs, still black. Tried manually changing the values, still black. They look the same as the crappy green subtitles only black.
Any help would be much appreciated.
Load the sup file in supviewer and have a look if there are wrong transparencies/opacities used (like background completely opaque black...)
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
My new subtitle problem
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2010, 03:32 -
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 16:54 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Menu swapping with IfoEdit - Problem solved
By Bingo-days in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 03:07 -
a problem with subtitle
By matrix man in forum SubtitleReplies: 1Last Post: 15th May 2007, 13:36
