I just downloaded TMPGE and encoded a AVI file to MPEG2,(2400) it played great on PowerDVD XP. When I encoded to a MPEG2 with Nero 5.5 I was having troubles playing back in PowerDVD with out of sync audio and video. I do not own a DVD player yet, but after seeing the results I got, I will purchase one. My question is when I encoded a pop up message came up and said I can only encode for 30 days MPEG2. How do I either purchase a MPEG2 encoder for TMPGE, or do I just download another copy of the software. I see they do not sell the software. Thanks
Hi,
I've created 3 files, a shorcut, batch-file and Registry file that resets the 30 days every-time TMPGEnc is RUN.
I can provide the files with an accompaning .txt file cause you'd have to edit the file paths.
There are other ways, I just coppied this from somewhere else. If you use the search function sometimes you'll find the answers you seek without having to wait for a reply.
The 30 day limit can be reset by deleting the following registry key:
HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}
Or, make a file "TMPGEnc_MPEG2_Reset.reg" with the following content:
REGEDIT4
; Enables TMPGEnc's MPEG-2 encoder for 30 more days.
[-HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}]
Hope his helps
Re-encoding HD MPEG2 video
By txporter in forum Video ConversionReplies: 27Last Post: 6th Mar 2010, 07:01 -
Edit MPEG2 video without encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Feb 2009, 14:05 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 10:25 -
Thoughts on Tmpgenc Express 3.1.5.82 Trial
By Batfink in forum Video ConversionReplies: 15Last Post: 30th Oct 2007, 02:17 -
MPEG2 to DVD without re-encoding
By nagihcim1 in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2007, 15:14
