Downloaded a film and joined all files with HJ SPLIT.
Now i have a xvid file some 716,206kb in size,whereas before all the individual files were 14,649kb in size.
My question is how do i enter it into the s2d programe to be converted ?.
I clicked on load assets tab and browsed to the folder to where this file is but it is not shown ????????.
Thanks very much
Results 1 to 11 of 11
Change the extension to .xvid or .avi
Changed extension to.xvid then changed it to .avi.
On both occasions nothing happened.
I mean after selecting either extension and clicking on open thats it ?.
It was not entered into the asset section at the bottom of the screen.
The film plays using WMP OR VLC.
I was going to post a log but none was created as i suppose it did not do anything to log. -
Can you send me a sample of the avi? (use the makesample tool in the Tools folder) I only need about a meg or so...
What you sent was a RAR file!!. Use WinRar to join those 14MB segments: this will give you the avi which will work in SVCD2DVD
I did join all the 14mb files together using hj split and it give me 1 new file which i took a 2mb sample from the e mailed it to you ??.
Since i sent it i have noticed every time i click on it or open the folder it is in the pc locks up and the desktop icons vanish so i have decided to delete it.
I will start again.
Cheers. -
the file was the start of a rar set. therefore hjsplit is no good to join them with - you need to use WinRar.
Downloaded another version and used winrar to join/extract all the separate files then burnt.
All worked ok and pc dont freeze up anymore.
Cheers.
Need advice on BR conversion
By tech3475 in forum Blu-ray RippingReplies: 3Last Post: 30th Apr 2010, 14:57 -
advice converting to XviD + removing commercials
By Colbey in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2010, 20:29 -
Advice for combining two WMVs and possible encoding them to Xvid?
By majax79 in forum Video ConversionReplies: 11Last Post: 14th Jul 2009, 22:22 -
Advice for batch mpeg2-xvid convertion please
By felix in forum Video ConversionReplies: 3Last Post: 5th Feb 2009, 06:53 -
Need advice on authoring XviD files to a DVD5
By alegator in forum Authoring (DVD)Replies: 9Last Post: 12th Jun 2007, 10:53
