before ya'll start yelling at me, YES, i did check every possible topic on this, and NO, i didn't find anything helpful.
to get to the point:
i have an LG dvd-rw burner. got it two weeks ago, and so far managed to write one data-dvd, and several cds and cd-rws. it burns cds and cd-rws great, but i cannot burn any video-dvds, nor data-dvds (just that one i burned the day i installed it).
it keeps telling me it cannot burn disk-at-once, and stops burning. i've tried all kinds of things (different settings, reinstalling nero, reinstalling windows, switching from winXP do winFD, etc) but nothing worked.
i've seen these types of probs before on other forums, but no one was helpful so far. i hope someone can help, for i'm growing quite desperate.
below is the error log, in case it helps anyone.
thank you.
_____
hal
team zissou
1A23-0009-9130-2346-5763-5017
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
Recorder: <HL-DT-ST DVDRAM GSA-4163B>Version: A102 - HA 0 TA 1 - 6.6.0.16
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST DVDRAM GSA-4163B>Version: A102 - HA 0 TA 1 - 6.6.0.16
=== Scsi-Device-Map ===
DiskPeripheral : IC35L040AVVA07-0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4163B atapi Port 0 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4163B F: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261616kB)
Free physical memory: 65MB (66896kB)
Memory in use : 74 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
13.10.2005
ISO compilation
00:13:39 #1 Text 0 File Isodoc.cpp, Line 6356
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : FALSE
00:13:40 #2 Text 0 File Reader.cpp, Line 127
Reader running
00:13:40 #3 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GSA-4163B running
00:13:40 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
00:13:40 #5 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
00:13:40 #6 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2138943 (475:19.18, 4177MB)
00:13:40 #7 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD DVD)
00:13:40 #8 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 003, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
00:13:40 #9 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
00:13:40 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2138944 (2138944) = #2138944/475:19.19
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2138944 blocks [HL-DT-ST DVDRAM GSA-4163B]
00:13:40 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4380557312, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2138944 | lead-out | 1 | 0x41 | 0x00
00:13:41 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
00:13:41 #13 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
00:13:41 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
00:13:41 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 12x (16,620 KB/s)
00:13:41 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
00:13:41 #17 Text 0 File Cdrdrv.cpp, Line 8862
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: MCC.....
Media type ID: 003
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 4D 43 43 00 00 - 00 00 00 30 30 33 00 38 ...MCC.....003.8
23 54 37 12 02 3C 6C 02 - A0 69 15 15 0B 0B 08 08 #T7..<l..i......
01 19 1B 0C 0C 0B 0C 00 - 00 00 00 00 00 00 00 00 ................
00:13:41 #18 Text 0 File DVDR.cpp, Line 5135
Drive: HL-DT-ST DVDRAM GSA-4163B
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
00:13:41 #19 CDR -1211 File DVDR.cpp, Line 5056
Book Type set to: DVD-ROM
00:13:41 #20 Text 0 File DVDPlusRW.cpp, Line 665
Start write address at LBA 0
DVD high compatibility mode: No
00:14:00 #21 SCSI -1135 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03C20000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x02 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x10
0x35 0x2D 0x00 0x0E 0x0C 0x00
00:14:00 #22 CDR -1135 File Writer.cpp, Line 311
Write error
00:14:00 #23 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
00:14:00 #24 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
00:14:00 #25 SCSI -1135 File Cdrdrv.cpp, Line 1180
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x10
00:14:00 #26 CDR -1135 File WriterStatus.cpp, Line 167
Write error
00:14:00 #27 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
00:14:00 #28 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 12x (16,620 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 11/03/2005 23:28:14 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 31/12/2002 12:00:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
I think the problem may be that you are not using "Burn DVD-Video Files" when you try and make a Video DVD. I did not see anywhere in your log that "DVD-Video files were being reallocated" unless I missed it.
the log i posted is from a data-dvd i was trying to burn. it doesn't work either way, data or video. :(
Help! Error When Attempting to Open MOV files in Virtualdub!
By lapetite_66 in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2010, 12:30 -
Question about new type of Nero 6 burn error
By jimdagys in forum DVD RippingReplies: 13Last Post: 29th Jun 2009, 00:22 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 20:58 -
Cannot burn DVDs, error message
By mataharimata in forum Authoring (DVD)Replies: 27Last Post: 22nd Mar 2008, 06:59 -
why could I only put two movies on a DVD disk when I use Nero to burn DVD?
By efang622 in forum Authoring (DVD)Replies: 7Last Post: 24th Oct 2007, 08:40
