AVI,MPG,DivX,XviD,MP3,AC3 video and audio formats
Just use Goldwave and open the video/audio and then save as WAV.
RM,RMVB,RAM,WMV,ASF,MOV,MKV,OGM,AC3,DTS,FLAC,etc video and audio formats
Download MPlayer-mingw32-1.0pre7.zip and extract it to a folder.
Download windows-all-20050412.zip and extract all codec files to the Mplayer folder.
Open a windows command prompt from the Start menu->Accessories->Command Prompt and type
"C:\Program Files\Mplayer\MPlayer.exe" -vo null -ao pcm:file=output.wav "D:\xvid.avi"
replace C:\Program Files\MPlayer to the location of Mplayer.exe
replace D:\xvid.avi to the location of the video or audio file
The output.wav will be located in the C:\Documents and Settings\Your Windows username folder.
Tips:
If you have downloaded streaming ram,asf files that you can't convert. Open the ram,asf file with notepad and you will see a line like rtsp://media.real.com/showcase/service/samples/28realaudio8.rm, copy it and use it as source like
"C:\Program Files\Mplayer\MPlayer.exe" -vo null -ao pcm:file=output.wav "rtsp://media.real.com/showcase/service/samples/28realaudio8.rm"
Example:
Convert:
WMV to WAV, ASF to WAV, RM to WAV, RAM to WAV, RMVB to WAV, MPG to WAV, AVI to WAV, DivX to WAV, XviD to WAV, OGM to WAV, MKV to WAV, MOV to WAV
Results 1 to 13 of 13
There is any easier way to conver rm to way or mp3 beside the MPlayer? I try and some how it does not work on my comp.
hmmmm... would this work for an "SAT" file, incase you are unaware of it, the SAT file is an encryption that's placed on any audio file that gets transfered into the Toshiba Gigabyte. I can't for the life of me find out how to convert it back when I transfer it back to my hard drive. I'm not unable to put any of that music on my hard drive or burn it onto a CD.
Thanx. -
wooo ...great! 8) thanks so much celtic_druid.
the 2 links to download in the first post are not working.
where i can download both and find one fast guide? -
Check the folders in the above links and you should be able to find newer versions.
thanks celtic_druid.
i only still can't find the "all codecs"....still searching! -
You mean?
http://www2.mplayerhq.hu/MPlayer/releases/codecs/windows-all-20061022.zip
Chances are that you don't need it anyway. -
yes,now i got!
one fast view inside the .zip and i don't have the quicktime.qtx and atrac3.acm...maybe some others i don't have too.
your post was like a gift celtic_druid,thank you so much.
8) -
Is there any way to get it to convert to different directory?
instead of C:\Documents and Settings\Your Windows username folder
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 10:07 -
need convert from audio caset to wav or mp3
By assi in forum AudioReplies: 6Last Post: 5th Nov 2008, 19:07 -
Best program to convert Audio Cassette Tape to WAV
By jimcornetet in forum AudioReplies: 8Last Post: 14th May 2007, 15:48
