Hello people I am new to this site so if this issue has already been answered I apologize for this post. I have a G4 Powerbook w/ OSX Tiger 10.4.2. I recently downloaded ffmpegX for it and it works great, but the only few problems I have are trying convert WMV to PSP MP4. Everytime I convert it the finishing file has nothing in it and the encoding part takes less than a second to finish it up. Right there tells me that there was nothing on it. But everytime I play the movie on my mac it works fine. CAn anybody help me?
The other quesion I have is that everytime I erase somehing off my memory card it still shows that the MB were taken up when actually there all erased. Does anybody else have that problem? PLEASE HELP GUYS!!!!!
Results 1 to 25 of 25
Help!
i've been having this problem too. Everytime I convert the finishing file has nothing in it. The file info tells me that there was nothing on it. But everytime I play the movie on my mac it works fine.
I have a Mac G5, working off Mac OSX 10.3 . Please someone help as this is driving me mad.
AL
You can lead a horse to water.....sheesh.
Okay, first off, PLEASE post what you get from the log when you press the blue "i" button.
Next, try experimenting a little. Does it encode if you select the XVID (mencoder)? If so, then we know it's something in ffmpeg. Also, try disabling the audio or the video when you encode so we can narrow down which part it's choking on.
In the words of Johnny-5 from Short Circuit: "Need Input!"
-macr0t0r
Going even more off-topic: you can play that in a browser these days: Lemmings
Thanks for the advice 'macr0t0r'
here's the info from the blue "i" button.
Encoding started on Tue Nov 15 09:05:22 GMT 2005
Input #0, mov,mp4,m4a,3gp, from '/Users/Creative2/Desktop/sw.mp4':
Duration: 00:01:10.8, start: 0.000000, bitrate: 141 kb/s
Stream #0.0: Audio: amr_nb, 8000 Hz, mono
Stream #0.1: Video: mpeg4, 176x144, 4.74 fps
Codec type mismatch for mapping #0.0 -> #0.0
I will try the other advice you mentioned. Fingers crossed.
Thanks again.
Al
Hi macr0t0r
just tried the select the XVID (mencoder). downloaded onto my psp but got the message "can not play video"
Arghhhhh!!!!
this is what the "i" button showed
Encoding started on Tue Nov 15 09:09:03 GMT 2005
MEncoder dev-CVS-050814-13:46-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x131b03
ISO: File Type Major Brand: 3GPP Profile 4
Warning! pts=571200 length=569600
Quicktime/MOV file format detected.
MOV track #0: 10 chunks, 357 samples
Audio bits: 8 chans: 1 rate: 8000
MOV: Found AMR audio atom damr (17)!
MOV: Vendor: PHLP Version: 0
MOV: Modes set: 0080
MOV: Mode change period: 0 Frames per sample: 10
Fourcc: rmas
MOV track #1: 336 chunks, 336 samples
MOV: Found MPEG4 movie Elementary Stream Descriptor atom (67)!
Image size: 176 x 144 (24 bpp)
Display size: 320 x 240
Fourcc: v4pm Codec: ''
MOV: longest streams: A: #0 (357 samples) V: #1 (336 samples)
VIDEO: [v4pm] 176x144 24bpp 5.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x7634706D size:176x144 fps: 5.00 ftime:=0.2000
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 8000 Hz, 1 ch, s16be, 128.0 kbit/100.00% (ratio: 16000->16000)
Selected audio codec: [ffamrnb] afm:ffmpeg (AMR Narrowband)
xvid: using library version 1.1.-125 (build xvid-1.1.0-beta2)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=352]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm:ffmpeg (FFmpeg MPEG-4)
Building audio filter chain for 8000Hz/1ch/s16be -> 48000Hz/0ch/s8...
Building audio filter chain for 8000Hz/1ch/s16be -> 48000Hz/1ch/s16be...
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
VDec: vo config request - 176 x 144 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 2 -> 2
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
videocodec: XviD (640x352 fourcc=44495658 [DIVX])
xvid: par=0/0 (vga11), displayed=640x480, sampled=640x352
xvid: CBR Rate Control -- bitrate=316kbit/s
4 duplicate frame(s)!
ODML: vprp aspect is 4:3.
5 duplicate frame(s)!
3 duplicate frame(s)!
6 duplicate frame(s)!
2 duplicate frame(s)!
1 duplicate frame(s)!
Flushing video frames
Writing AVI index...
Fixing AVI header...
Video stream: 71.151 kbit/s (8893 bps) size: 628977 bytes 70.720 secs 336 frames
Audio stream: 128.000 kbit/s (16000 bps) size: 1139712 bytes 71.232 secs
Encoding completed on Tue Nov 15 09:09:26 GMT 2005
Does this help. Will try disabling the audio or the video next.
Many thanks
Al
Okay, now we're getting somewhere. It works for mencoder, but not ffmpeg. I've had this occur with some files (for instance, only Mencoder can convert RealAudio files). Please post what you get in the log (blue i) when you encode using your original settings.
And please do try, using your original ffmpeg encoder settings, to encode with either the audio or video disabled and post the log results.
I'm not exactly a power-user, but I have one solution in the meantime. I've had some files that only mencoder could digest (RealVideo). In those cases, I would first convert to XVID AVI (mencoder) using a very high bit-rate for both video and audio, then convert the resulting file using the PSP preset. I understand that there might be a slight loss in quality, but it got the job done. Since I was scaling down to 320x240, I would hardly notice the quality-reduction anyway.
- macr0t0r- macr0t0r
When did email start feeling like work?
It works!!
Thanks 'Macr0t0r'.
Process i went through was:
convert .avi file to XVID AVI (mencoder). Then use this converted file through the PSP settings.
Then finally, download your file to the PSP.
Only thing at the moment is, i have to start with a .avi file.
Do you know of a good shareware software for the Mac which can convert .mov (quicktime) to .avi files?
Thanks ever so much for help. I owe you a drink.
Al ( a happy person)
Odd. From my experience, ffmpegx can already handle .mov files. I have converted such files in the past.
Have you tried it and received an error? If so, it's time to hit that blue 'i' again!- macr0t0r
Ok, here's the info from .mov file to XVID AVI (mencoder). sorry it's quite long.
Encoding started on Fri Nov 18 09:08:22 GMT 2005
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x2eca17
MOV: selected audio stream (1) does not exists
MOV track #0: 13 chunks, 0 samples
Audio bits: 16 chans: 1 rate: 22050
Audio extra header: len=88 fcc=0x77617665
MOV: Found unknown audio atom Fourcc: 2MDQ
MOV track #1: 1195 chunks, 1195 samples
Image size: 160 x 120 (24 bpp)
Display size: 160 x 120
Fourcc: 362h Codec: 'H.263'
MOV: longest streams: A: #0 (13 samples) V: #1 (1195 samples)
VIDEO: [362h] 160x120 24bpp 10.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x33363268 size:160x120 fps:10.00 ftime:=0.1000
Selected video codec: [ffh263] vfm:ffmpeg (FFmpeg H.263+ decoder)
VDec: vo config request - 160 x 120 (preferred csp: Planar YV12)
xvid: CBR Rate Control -- bitrate=1265kbit/s
2 duplicate frame(s
Video stream: 511.171 kbit/s (63896 bps) size: 7634343 bytes 119.480 secs 1195 frames
Encoding completed on Fri Nov 18 09:09:43 GMT 2005
Now the 'i' blue info from XVID (mencoder) to PSP settings.
Input #0, avi, from '/Users/Creative2/Desktop/nation.mov.ff.avi':
Fri Nov 18 09:15:19 GMT 2005
00:01:59.4, start: 0.000000, bitrate: 516 kb/s
Stream #0.0: Video: mpeg4, 640x352, 25.00 fps
Number of stream maps must match number of output streams
Do you think i should try from .mov to XVID (ffmpeg) then to PSP setting?
thank you.
Try to remove the .mov extension from your source file, then use "XviD ffmpeg" (also disable "Normalize audio" in the audio tab).
removed the .mov from the file name. Then used 'Xvid ffmpeg' (could not find 'normalize audio' in the audio tab so i unclicked 'encode audio')
i blue info:
Fri Nov 18 13:03:10 GMT 2005
Input #0, yuv4mpegpipe, from 'pipe:':
Duration: N/A, bitrate: N/A
Stream #0.0: Video: rawvideo, yuv420p, 640x352, 25.00 fps
Output #0, avi, to '/Users/Creative2/Desktop/nation.mov.ff.avi.e.avi':
Stream #0.0: Video: xvid, yuv420p, 640x352, 25.00 fps, q=2-9, 1265 kb/s
Stream mapping:
Stream #0.0 -> #0.0
bench: utime=54.880s
video:18423kB audio:0kB global headers:0kB muxing overhead 0.412501%
Encoding completed on Fri Nov 18 13:04:23 GMT 2005
FROM Xvis ffmpeg to PSP setting.
'i' info
Input #0, avi, from '/Users/Creative2/Desktop/nation.mov.ff.avi.e.avi':
Fri Nov 18 13:05:33 GMT 2005
Duration: 00:01:59.4, start: 0.000000, bitrate: 1268 kb/s
Does this make sense? Guess i might have to quit and take what i have been given so far by your help. O'well.
Al
You must not disable audio encoding. Perhaps "Normalize audio" was already disabled with ffmpeg engine so you don't need to set anything. Just encode without the ".mov" extension and see.
sorry 'major' .... No luck
removed the ".mov" extension from the quicktime file. Used Xvid ffmpeg settings.
file it gave was 'zero' k in size.
"i" info:
Fri Nov 18 14:04:48 GMT 2005
Seems that stream 1 comes from film source: 2500.00 (2500/1) -> 10.00 (10/1)
Input #0, mov,mp4,m4a,3gp,3g2, from '/Users/Creative2/Desktop/nation':
Duration: 00:01:59.5, start: 0.000000, bitrate: 205 kb/s
Stream #0.0: Audio: 0x324d4451, 22050 Hz, mono
Stream #0.1: Video: h263, yuv420p, 160x120, 2500.00 fps
Ah...I see the glitch. This is an old-style Quicktime format. Okay, do the following:
1. Select Summary Tab:
a. Drag your Quicktime Movie to the left side.
b. Select PSP on the right side.
2. Select Options Tab:
a. Enable the "Decode with QT" checkbox
b. Make sure the "Letterbox" is enabled if this is a letterbox-format video.
3. Encode and tell us how it goes.- macr0t0r
hi macr0t0r.
followed your steps. still gave a zero file size.
steps i took:
1. .mov file convert to Xvid mencoder.
2 Xvid file convert to PSP setting
clicked 'decode with QT'
blue i info
Mon Nov 21 12:10:02 GMT 2005
does this mean anything? i converted a file to .avi and then ran it through Xvid mencoder > psp mp4.
Encoding started on Mon Nov 21 17:15:52 GMT 2005
Input #0, avi, from '/Users/Creative2/Desktop/star/trek.avi.ff.avi':
Duration: 00:06:57.7, start: 0.000000, bitrate: 1187 kb/s
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
Output #0, mp4, to '/Users/Creative2/Desktop/star/M4V06530.MP4':
Stream #0.0: Video: xvid, 640x352, 25.00 fps, q=3-9, 300 kb/s
Stream #0.1: Audio: aac, 24000 Hz, stereo, 32 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
video:15331kB audio:3266kB global headers:0kB muxing overhead 0.858083%
bench: utime=210.780s
1 video MPEG-4 Unknown Profile(0), 417.720 secs, 98 kbps, 640x352 @ 25.00 fps
Warning:fps must 14.985 or 29.97.
2 audio MPEG-4 AAC LC, 418.090 secs, 98 kbps, 24000 Hz
Ready.
THANK YOU TO ALL WHO HAVE SUGGUSTTED IDEAS, SORRY IF I HAVE BEEN A PAIN. I JUST HATE BEEN BEATEN.
Just to let u know i can convert .avi files from my digital camera to the psp with no problems. just don't understand why any other .avi files won't work. mmmmm...
here's the info for avi (camera) to psp
Input #0, avi, from '/Users/Creative2/Desktop/MVI_0128.AVI.ff.avi':
Duration: 00:00:41.7, start: 0.000000, bitrate: 922 kb/s
Mon Nov 21 17:36:36 GMT 2005
Stream #0.1: Audio: mp3, 48000 Hz, mono, 128 kb/s
Output #0, mp4, to '/Users/Creative2/Desktop/M4V05435.MP4':
Stream #0.0: Video: xvid, 320x240, 29.97 fps, q=3-9, 300 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
video:576kB audio:299kB global headers:0kB muxing overhead 111.990895%
bench: utime=12.900s
1 video MPEG-4 Unknown Profile(0), 41.641 secs, 98 kbps, 320x240 @ 29.97 fps
2 audio MPEG-4 AAC LC, 42.069 secs, 98 kbps, 24000 Hz
Encoding completed on Mon Nov 21 17:36:50 GMT 2005
Man, I am really at a loss on this. Does the new version work for you? It really SHOULD WORK since the AVI was created by ffmpeg to begin with.
- macr0t0r
.wmv/.mov to psp mp4 not working
By JJeweler17 in forum ffmpegX general discussionReplies: 11Last Post: 4th Aug 2007, 00:35 -
.wmv file to psp for a mac
By melacanth in forum Newbie / General discussionsReplies: 0Last Post: 3rd Aug 2007, 22:43 -
mp4/psp sounds problems
By Nick1982 in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2007, 15:22 -
MP4 (PSP) EDITOR help
By efiste2 in forum EditingReplies: 6Last Post: 29th Jun 2007, 13:54 -
psp and mp4's
By zinc in forum Portable VideoReplies: 4Last Post: 19th Jun 2007, 13:50
