I have two files, when I use TDA to do Source Setup, I try to add "Usher- Yeah" (mpg) and it is ok. But when I try to add "2 Pac- Changes" it says that "a video sequence header is necessary. What does that mean?
Than I try to add a DVD Video and look for the TS folder that I created using DvixtoDVD in the 2 Pac Changes folder. It gives me some sort of error. Can any one help?
I cannot click ignore. Is something missing?
TDA lets me convert mpg to dvd format right? Or do I have to use TMPGEnc for that?
thank you
try remultiplex/fix the 2-pac video with videoredo, https://www.videohelp.com/forum/viewtopic.php?p=1377404#1377404
what is the exact error when you import the video_ts ? -
it says somethign along the lines of video header sequence is necessary for every GOP in a standard DVD and that the video header sequence is incorrect. The funny thing is that DivxtoDVD burned it fine. The problem I have with this software is that it doesnt give you a total time like how TDA does, so you can track how much u can burn on a 4.7 gig dvd-r. DivxtoDVD kinda just burns it, unless someone else can tell me otherwise.???
Ok I think I figured it out, I need to use TMPGEnc 3.0 XPress to convert my mpg and vcd to a dvd-compliant video. Then I use TMPGEnc DVD Author to make menus? I would click the "add DVD-Video" and find the vob files right?
Why does it have a "add file" why would you need to author non-dvd files?
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 18:04 -
VIDEO TS sequence
By red lion in forum EditingReplies: 1Last Post: 25th Jun 2007, 19:15
