    Oct 2005
    Boulder, CO
    I want to make a copy of a DVD I burned with iDVD. I used mac the ripper to extract the files from the DVD, but I don't know where to go from here to burn a new DVD that will work. Whats the word on this?
    Thanks for any help,
    matt
  2. Master of my domain thoughton's Avatar
    England
    DVD2OneX, followed by Toast. Do a search, there's at least ten thousand posts in this forum on this very subject
    Tim Houghton
    WebsitePhotography
    Jan 2005
    Internet
    You really only need MTR if the DVD has a copyguard on it.
    Mark V
    10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D
  4. Roxio Popcorn or Roxio Toast can both be used.
    They both can copy DVDs easily.
    Both also have compression capabilities to squeeze a large disc to fit onto a standard blank DVD.
  5. You would need toast 7 to do the compression, toast 6 will not compress. Or Popcorn or DVD2OneX (which I prefer). Of course if the resulting file is less then 4400mb or you are using a DL disc then you will not need to compress.
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    You don't need to compress it if the DVD media you burned to is the same size the new DVD media is. No need for iDVD, no need for DVD2One, no need for Mac THe Ripper. Just open Toast and select the copy funtion. Plain and easy.
    Aug 2004
    use disc utility to image the DVD, then burn it.
