I'd like to run the output of my MP3 player (headphones) to the input of my stereo receiver (line audio). They sell FM transmitters, but the one I tried didn't work well at all. I've tried running a direct cable and that was even worse. Any suggestions? Thanks in advance.
wwaag
Originally Posted by wwaag
My son does the same with his IRiver and it works great.
Was it distorted or what? -
Radio Shack sells an adapter made by Monster Cable for this purpose.
Yes, even if phones out isn't intended for line in, it usually works. "Even worse" how?
/Mats -
mp3 players work well with computer speakers just pull out the line put it into your mp3, or buy one for your mp3 player
Thanks for the replies. Yes, it does "work" going directly from the headphone out to line in. However, you have to really crank up the volume (on both the mp3 player and stereo receiver) and the resulting sound is rather "hollow or tinny" for want of a better description--it just doesn't sound good. I also have a cassette adapter which actually works quite well in my car system. Again, thanks.
wwaag -
Sounds odd, as the levels for line in is lower than generally phones output, AFAIK.
Maybe some impedance mismatch is giving you the problems. Not much to do about it then.
I've had a number of portable CD players in the past with both phones and line out - a pity MP3 player manufacturers hasn't adopted that feature.
/Mats -
are you sure you're using a stereo adapter, not mono?
I am just a worthless liar,
I am just an imbecil
Tv with no headphone jack AND rca audio outputs
By gordes04 in forum DVB / IPTVReplies: 27Last Post: 23rd Jun 2013, 21:39 -
Any ideas on why audio through headphone jack stutters on MacBook?
By ryangarfield in forum ComputerReplies: 2Last Post: 30th Mar 2010, 22:07 -
Record audio from PC headphone output
By Galadirith in forum AudioReplies: 0Last Post: 25th Jun 2009, 12:43 -
Realtek audio card front headphone socket
By didikai in forum ComputerReplies: 8Last Post: 19th May 2008, 09:49 -
Is there a such thing as a headphone plug adapter from a rca audio port?
By moomooemu in forum Newbie / General discussionsReplies: 10Last Post: 11th Dec 2007, 00:48
