I am having a problem with DVDecrypter, and since support is no longer available, I am posting this here hoping that others that may have had this problem have sucessfully solved it.
I am using DVDecrypter on a WinXP Pro system to extract video and audio streams from a DVD that was recorded on a Samsung recorder (don't remember the model number right now). All is well until Decrypter finishes. Instead displaying the notification that it's finished, it just freezes. When this happens, looking into Task Manager shows that some seemingly random process (svchost; winlogon; explorer to name a few - there were others) has bumped the CPU usage to 50%, and can't be stopped by ending the process. The only way to stop this condition is by powering down the computer (Start-shutdown doesn't work either. I have to pull the plug and I know it's only a matter of time before system files are corrupted because of this).
Has anyone else had this problem? If so, how did you correct it?
yes. be patient.
I am just a worthless liar,
I am just an imbecil -
Do you have nero installed on your pc. And if so, do you have it checked in DVDCRYPTER to burn with NERO. This is a known issue if so. IF not, I'm at a loss.
Rob -
The first time it happened, I shut the monitor off and let it run overnight. When I turned the monitor back on in the morning, the computer was in the same state it was in the night before. I admit that I have little patience for this sort of thing, but it seems to me that 7 hours is long enough to wait.
@Harley2Ride - No, I don't use NERO. The burner I have installed is Sonic RecordNow.
ripbot264 not working properly with Windows 7 x64 - finishes in 1 sec ???
By xlr8r18 in forum Blu-ray RippingReplies: 14Last Post: 8th Jul 2011, 20:04 -
Repeating last frame until audio finishes - Premiere Pro
By LAM_ in forum EditingReplies: 3Last Post: 20th Apr 2011, 07:57 -
my computer freezes
By bits27 in forum MediaReplies: 20Last Post: 9th Sep 2009, 01:35 -
Conversion finishes in a seocond !!!
By shori in forum ffmpegX general discussionReplies: 19Last Post: 17th Mar 2008, 09:53 -
VOB to DV last VOB file finishes in about one second w/no data
By Gizmology in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 18:39
