  1. I am using TMPEGEnc DVD Author 1.5 and when I record my video sometimes the audio dont match the video. Is there a setting or something im doing wrong ?
    Apr 2004
    Miskatonic U
    What's the source ?
    Did you convert it ? If so, how ?
    Does it play together BEFORE you load it into TDA ?
    Read my blog here.
  3. The source is a video from recording TV off my Sat Card. First I have to patch the header with DVDDecryptor then I use Tmp 1.5.
    It does play fine as a mpeg video on the media player.
    try demultiplex/fix the recording with projectx or pvastrumento first.
    and do you mean patch with dvdpatcher? cause dvddecrypter can't patch headers.
  5. yes, I got confused yes im using DVDpatcher.
    I will try what you suggest, Thanks
  6. OK, im using the PVAastrumento and now it made me 4 seperate files. I was hoping it would repair the existing clip. So how would I use these 4 files in TMPGeng 1.5 ? Or will I have to convert what PVA repairedand make it 1 clip again ?
