I have been given a copy of an 1990's film on dvd and when I play it the picture is in a box in the middle of the screen. The black borders are 2 to 3 inches all round. The TV is a 25 inch NOT wide screen which shows everything else fine. I also get the same problem if I play the DVD on my computer.
Is there a way I can convert/reauthor it to make it normal size on the screen
Are the black bars steady? In other words, do they move around at all? If not, you could use something like virtualdubmod to crop the video and resize it. It'll be a relatively complicated procedure and will cause fair quality loss. Might be easier to just buy a new copy of the movie.
Veni Vidi Vici -
It could also be a 4:3 film that has been encoded as 16:9. Your DVD player will be playing it letterboxed, with the widescreen black bars above and below, and the pillarbox bars to the side. If this is the case, resizing becomes even more complex.
Read my blog here.
It's possible whoever originally encoded the DVD added the bars to compensate for bad overscan problems. Who knows? Does the video have burnt in subtitles? Some people add bars all the way around to make sure the subtitles show on the screen.
Veni Vidi Vici
Is there a wireless device to control a cable box remotely and send picture
By MrBiggZ in forum Newbie / General discussionsReplies: 4Last Post: 5th Jan 2012, 19:18 -
Removing middle-of-the-screen tearing from VHS tape
By vectorthom in forum Capturing and VCRReplies: 0Last Post: 16th Apr 2010, 17:24 -
Small picture in middle of screen - burned DVD in Nero Vision
By bigj7489 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 17:20 -
Power DVD : picture hidden behind black screen???
By HBM in forum Software PlayingReplies: 2Last Post: 14th Sep 2007, 01:43 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 03:37
