Hi
I have a Toshiba SD220 E dvd player which was working fine as in region free until playing a small 8mm dvd rom from a camcorder yesterday, there was obivously somehting wrong with the DVD from the camcorder as the DVD doesnt want to play any music, or DVDs etc now
The main menu screen is now displayed in B&W and half the setup menu items have disapeared.
I had previously downloaded the region free crack disc, but in the intructions it says you need to go into setup and then under picture, it should display PAL/Auto, under picture im only getting the option of letterbox, widescreen, or normal theres no option of PAL or Auto, also the screen is only in black and white now, HELP!!!!!!!!!!!!!
Appreciate it if somebody could email me directly to shawnwilliams@cellular10.freeserve.co.uk
Rgds
u need to dload the rar file at http://sd220e.chez.tiscali.fr/ to get your region 2 Toshiba sd220e region free. It works great. This is what you need to do
- Download the rar file at the link provided by Labman
- Unpack it using WinRAR
- Start Nero Burning ROM, click File, click Burn Image..., select the .cue file, click open, disable 'Determine maximum speed' and 'Simulation', at write method select Disc-at-once (this is very important), click write.
- Push setup on the SD220e remote control, select under picture:
PAL/Auto: Auto. Push setup again.
- Open your SD220e disc tray and insert the CD.
- Close the disc tray.
- The disc will be read and recognised as a VCD, you'll see the image on
your television flash and after a short while you will not see any image
at all. Wait about 10 seconds and take out the CD.
- Your player is now region free. Tested it with a region 1 DVD and it
worked great.
If you have any questions email me at jezbown@blueyonder.co.uk or jezbown@btinternet.com
Results 1 to 1 of 1
medial player stopped playing my movies
By CheekyKid in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2010, 01:26 -
LG GSA-4160 stopped reading DVD-RAM disks.
By lennyt in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2008, 14:56 -
Toshiba RD-XS35 won't play some disks
By inferno7 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th May 2008, 14:18 -
GoldStar GSA-4160B stopped reading DVD-Ram disks
By lennyt in forum DVD & Blu-ray WritersReplies: 3Last Post: 2nd Jan 2008, 12:12 -
Toshiba A2 and DVD-R disks
By Prot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jul 2007, 19:28
