I have troubles with dropped frames when i capture my tapes using Adobe Premiere. So i end up with lots of smaller files.
I want to combine them again into a large file, so i have one scene in one file without re-encoding?
I could edit the clips into 1 file in Premiere, but what export settings would i then use so that i'm sure that no re-encoding takes places?
Thnx
edit: fixed typo in subject
Okay, i suspect that virtualdub might do the trick. But can i perform that cut&paste actions in premiere as well? (I'm used to that interface)
grtz -
Hi aardbij,
Welcome to the forums.
Try WinDV to transfer your DV to PC. It's free, reliable and stable. You can only transfer using firewire.
Set WinDV up like this...
...to get each seperate clip into its own file, or set the "Discontinuity threshold" to zero to get the entire tape into one DV AVI file.
If you still want to use Premiere, then export as DV AVI for no loss.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks for your help. I really appreciate it.
I checked out WinDV and it worked like a charm. For me, it works even better then Premiere because it adds the orginal date/time stamp to downloaded scenes. Strangely, my premiere 6.5 doesn't provide anyway to get that stamp (not even in the file properties).
A small improvement for DV should be the play/stop/ff/rew buttons. I had to use the buttons on my camera.
About your suggestion on using the DV AVI export format. I assume that as long as i dont use any image manipulation (like transitions) but only simple cuts, i wont reencode and just direct-stream the clips into on bigger file?
greetz
aardbij -
So, if you do anything in Premiere - transitions, cuts, effects, picture enhancements, adding pictures (stills) or titles - when you export as DV AVI there'll be no quality loss in the original footage as the rendering for the tramsitions, effects etc. is done in DV AVI (that's a default for Premiere).
Hope that helps...
P.S. Some tools you might find useful if you're interested in the timestamp:
DVdate
DVE Dv date
DV_Datecode
Visual DV Time StampThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Font size is sometimes big and sometimes small
By Fire Foxer in forum SubtitleReplies: 0Last Post: 25th Aug 2010, 14:23 -
Cut HD files (h264/avc) without reencoding
By cd090580 in forum EditingReplies: 3Last Post: 25th Jun 2010, 18:37 -
Combine all the software disks and create 1 big boot disc?
By dnmnbg in forum ComputerReplies: 6Last Post: 29th May 2010, 22:17 -
is it possible to author a BR usig m2ts files without reencoding?
By Onceler2 in forum Authoring (Blu-ray)Replies: 6Last Post: 5th May 2010, 10:23 -
vdub virtualdub can I combine several small avi files into one
By case310350 in forum EditingReplies: 2Last Post: 5th Jan 2009, 02:23
