I need to create a series of videos for playback on a PC in Windows Media Player... not as a DVD as the 'play list' of files will be regularly changed/added to.
Also needs to cope with 16:9 and 4:3 aspect ratios in PAL
I'm coming from Final Cut Pro so can generate a high quality QT or output for Mpeg 2 (but creates 2 files... a .m2v and a .aiff)
Can these 2 files be simply muxed in ffmpeg?
I've tried a few options in ffmpeg but find many of them confusing!
I've got ffmepgX 0.0.9p.... would moving up to a more recent version help?
TIA
Steve
AIFF is not recognized so you should first convert it to WAV with Quicktime Player. Then use the "Mux as DVD" tool to mux m2v and WAV and it will create a MPG file (disable the 'author as DVD' option to avoid creation of the VIDEO_TS folder). Switching to the most recent version -always- helps.
Well that did and did'nt work!
The encode to .wav thro Quicktime OK. The mux thro ffmepg OK.
The resulting .mpg file plays OK in Quicktime on the Mac but 'sticks' after about 20 sec of play back on Windows Media player - the video stops playing whilst the audio continues to play???
Tried some diffrent files and lowering the bit rate of my original m2v file but still the same????
Steve
Add DVB Subtitles to MPEG2 Muxed (mpg) file
By edrin in forum SubtitleReplies: 0Last Post: 26th May 2010, 15:47 -
Best way by using MPEG STREAMCLIP to convert MPEG2 Muxed at 720 x 404 ?
By DTRON in forum Video ConversionReplies: 1Last Post: 21st May 2010, 16:22 -
Probable Codec problem. No audio on MPEG2 muxed files
By Kevlin in forum MacReplies: 14Last Post: 17th Apr 2010, 03:05 -
Help needed with Avi2dvd "hiccup" (muxed mpeg2 avail but didn't f
By bgart13 in forum Video ConversionReplies: 2Last Post: 17th Apr 2008, 17:54 -
How do I make a muxed mpeg2 data file using ffmpegx?
By tjaca51 in forum Video ConversionReplies: 0Last Post: 13th May 2007, 23:20
