hi..am a newbie in conversion from dvd to vcd...well here goes
I don't have a dvd player or dvd-burner only cdrw...I downloaded a dvd iso (~4GB) from the web...what I want to do is convert it to VCD format.
What tool should I use and the simplest procedures if any1 can help to tell me...thanks
Results 1 to 12 of 12
Mount the ISO with daemon tools.
From then on, it's just a std DVD to VCD conversion for which many guides have been written.
/Mats -
Hi Mats, thanks for the quick response. I did what you told me. I downloaded and install daemon tools...but when it loads up it says "invalid device".
For your information, I am using Pentium Celeron P2.4Ghz running on Win NT. -
So, you say as soon as you start daemon tools, it stops with the error message you give? Or is it when you try to mount the ISO? What version of NT are you on? If 4, I hate to say this, but you really should get W2000 (NT5) or XP Pro (NT 5.1). Not much that supports NT4 these days...
Daemon tools has always worked for me. But there are other "virtual CD/DVD" applications out there - Nero comes with one.
/Mats -
yup it pops up the msg each time my pc starts up. I installed it in another Win2K machine and it works fine. So I believe it is something to do with Win NT.
You mentioned there are others virtual vcd/dvd apps out there...can you name a few. Nero I have version 6 but where do I get that application which you are saying? -
Did you seriously say you "downloaded" a DVD ISO - Public domain file I assume right?
Try Alcohol 120% as well to mount and process the now accessible DVD however you wish.
Please dude, never say "i downloaded this or that" say simply that you have a file that I want to,,,,,,
Paranoid??? Yes I am!!!No DVD can withstand the power of DVDShrink along with AnyDVD! -
In Nero, I think it's called "Nero Image Drive" or something similar. A quick google for "virtual DVD" turned up this...
/Mats -
Yes, you are. "Downloaded" is not a violation of AUP. (Even if it adds nothing to help solving the issue.) Do you always go up to people and tell them you suspect they've nicked the jacket they are wearing in the street?Originally Posted by jtoolman2000
/Mats -
If the tag is still hanging then yes
Do you seriously believe that a downloaded ISO of DVD that someone is so feverishly trying to convert to something playable is not a commercial movie? I don't think it is a documentary of the mating habits of the blue whale capture from the BBC!
We have developed this "Look the other way" attitude around here lately.No DVD can withstand the power of DVDShrink along with AnyDVD! -
I'm sure you do.
It's of no significance what you or I believe/think or not. It's what's stated. And what the mods read into it. Until Baldric puts "Don't mention 'downloaded' in subject and/or text" into the AUP, it should be fine with everyone.
I think there's developed a "mod wannabe" attitude lately...
/Mats -
ok guys...coem back to my problem..hehehe..
i manage to load daemon on a WIn200 machine...and I use eazy VCD to convert the DVD to VCD...if I play at the standard 100% windows for Media Player the pictures are quite clear, but if I choose full screen...yiekss...the quality distort so much...any hints on how to produce a better vcd ? any better freeware converter or anything...pls help -
I think you're asking too much of the VCD format. It's the lowest acceptable standard there is, when it comes to video - at best like a slightly worn VHS tape. Making that full screen on a high def computer monitor brings out all the ugliness.
VCD is a tight standard, and there is not much to do to tweak the output, than to have the best source material available, like a DVD.
EazyVCD is rumored to be one of the best DVD to VCD allinone converters there is.
Try it on your TV - that's what VCD is intended for. It will not look as bad as on the monitor.
If your goal is to play it on the computer, go for AVI XviD or DivX.
Best mpg1 encoder (subjective judgement, I know!) is TMPGEnc, but then you have to take a lot of steps both before encoding and after, in the process from DVD to VCD. Which, is described in the guides.
/Mats
Burn Multiple ISO's to one DVD with Menu
By AHWagner in forum Authoring (DVD)Replies: 10Last Post: 4th Jul 2011, 19:54 -
how to burn mkv to iso to dvd??? my quad core machine is down.. and i need
By landocass in forum Newbie / General discussionsReplies: 7Last Post: 26th Jan 2011, 02:49 -
How to burn 8.3G iso movie file to dvd double layer disc?
By ibearzz in forum DVD RippingReplies: 12Last Post: 21st Oct 2007, 20:47 -
Can't burn .iso image file onto the DVD+R
By BabaKali in forum Newbie / General discussionsReplies: 12Last Post: 26th Sep 2007, 06:44 -
Burn a cd iso to dvd?
By jimminy_kriket in forum Newbie / General discussionsReplies: 6Last Post: 4th Jul 2007, 01:41
