Ok so i wanted to edit the background pic of a menu, found this guide:
http://forum.doom9.org/showthread.php?s=&threadid=93257
Followed it to the T (or so i thought) and the end result is that when i load up the movie the highlighting around the menus won't work, but if you click the menus it will bring u to where you want to go.
This is what i did:
Extracted cell i wanted to edit in vobBlanker.
Extracted that VOB with vobrator
Edited my background
Extracted the subpic in the main vob using subrip.
Created a .SST file which points to the correct path and correctly named .BMP file.
Used Muxman to recompile the bg.bmp the audio file and the subpic
Saved
Loaded vobBlanker and replaced the menu cell with the new VOB
Went to PGCedit and loaded the menu and imported the buttons and color schemes in which i previously exported. Saved
Loaded and nothing WTF!!!?
Results 1 to 9 of 9
Hi-
Sorry, but I can't pinpoint the problem with what you did. However, I've followed this guide several times with success:
http://forum.doom9.org/showthread.php?p=555936#post555936
One advantage is that you don't have to mess with the sub pics. Even if you decide not to do it all over again following this guide, it may give you some clues about any steps you may have left out or done wrong. However, that guide doesn't really seem to be about editing a menu pic and replacing it, but replacing an entire original menu back into a video. If I understand correctly what you want to do, the guide linked above may be better suited to your purposes. -
Thanks for the reply, i'll give this a try although seems a bit more complicated, anyway using this method will it allow me to have a highlight or does the highlight go away?
sorry about the repost, i got everything working after some tinkering, one question though, i'm trying to edit one of the special features menu's and i want to add music, how can i do this when remuxing? Thanks.
Sorry, I can't help you there, as I've only ever followed the guide to which I linked earlier, and after editing the pic, stuck just the M2V back into the original Menu. I didn't have to do anything with the audio. Perhaps authoring it with Muxman or IFOEdit, at the same time adding the audio, and then adding that cell back into the menu using VobBlanker following your original guide will work. But I just don't know. Perhaps someone else around here can help. -
Not sure using muxman would work because than i think i would have to extract the subpic (highlight) and add it back to muxman when creating the new vob which i am not good at, tried doing that with another guide and came up short, so far this works well but i just need to add that lil peice where you can add the audio and i'm set.
Hi-
I've been trying for the last hour to find how to do what you want, not because I'm such a nice guy, but because I may want to do the same thing myself some time. After coming up with some dead ends, I think I've found a guide for what you want. You've already done some of the work required:
MODIFY A DVD-MENU WITH MUXMAN
In the same manner you can modify a 4:3 menu of a commercial DVD. You can change the text of a button, add a button, delete a button, change the background picture (or the background movie), change the audio track or make all other changes you can think on.
There are all kinds of other posts in that thread (including one for using the same method for a 16:9 menu), some of which may help you to get your original VobBlanker method working correctly. If you decide to tackle the job, please let me know if you wind up with what you want. -
hehe, thanks for the post, funny that you mention that i am following that guide, asking in that thread how to add the audio. If i get it i'll post here.
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 09:42 -
NeroVision: DVD menu chapters highlight in wrong order
By Grunberg in forum Authoring (DVD)Replies: 0Last Post: 26th Apr 2011, 18:35 -
Menu button won't highlight
By mattblack in forum Authoring (DVD)Replies: 3Last Post: 21st Oct 2010, 17:45 -
How to change highlight delay in authored menu?
By gsh in forum Authoring (DVD)Replies: 3Last Post: 17th Sep 2009, 10:09 -
PGCEdit question: setting menu button highlight positions for letterbox
By Alex_ander in forum Authoring (DVD)Replies: 10Last Post: 5th Jun 2008, 11:55
