hi all, i had this dvd writer after i update to the latest f/w 1.20 couple days ago and now i having a problem writing cd and dvd disk with it, everytime i tried to burned a music or a movie dvd or cd files near the end of the disk verify or disk finallizer it said burning processing fail, but even though the cd working fine in home stand alone cd player. it never happend before. im using nero 6 platium burning soft dvd shrink and dvd decrypter.
seem like this f/w gave me problem after i updates it.
is it anywaw i can go back to the old firmwares which come with the writer or not? i had try to update back the f/w 118 or 114 it wont let me do it. how to delleting the f/w.
it said i had the latest f/w for this drive. can you help me to fix it.
thanks
If I was you what I would do si download the older firmware and use DVRFlash to go back to the previous version. As far as I know the updater from Pioneer will not allow you to flash back. I tried the 1.20 as well and had problems and ended up going back to 1.14 from NIL.
Smurf you have any suggestions for this guy?The real answer lies in completely understanding the question!
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 09:03 -
Problem with video out on Pioneer DV-490V
By Benhermies in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Apr 2010, 16:52 -
Pioneer DVR 533HS Problem
By Hollywood_Mike in forum DVD & Blu-ray RecordersReplies: 25Last Post: 13th Aug 2008, 12:35 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 05:36 -
Pioneer DVR 533 Problem -
By chris_james in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Aug 2007, 02:59
