    Oct 2005
    akron, oh
    ok so i put my 5 files i want on one dvd and click finish , i try to choose the option to author with dvdstyler after conversion, but i always get an error and diko closes? whats that all about? did anyone have similar problem they figured out?
    what is the error?
  3. Go to the DIKO Website Forums there are a few topics on the subject do a search, it depends on what version you are using but there was a bug in one version
    http://www.vmesquita.com/forum/
  4. Member srenaud's Avatar
    Jan 2002
    Elburn, IL USA
    Make sure you do not have a space in any of the paths to your files / work folder.
    Also, I had to launch DIKO standalone, before it would work called from diko.
    Other than that a great combo package.
