  1. Member nil_3's Avatar
    Oct 2005
    kolkata
    How can I create a back-up DVD by taking two different movies from two different DVD discs so that the newly created DVD will be menu-based and the sub-titles of the initial DVD movies will remain intact? Please mention if there is any free software available.
    Apr 2004
    Miskatonic U
    There is no free software to easily do this and keep the menus intact. Probably the easiest software to do this is DVD Remake Pro, a payware application that can join two disks and add a simple Movie One / Movie Two menu at the top level.
    Read my blog here.
  3. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Or you can use dvd shrink to get both movie titles you want with the sub titles, and then get a trial of dvd author (if your only going to use it for this one use, other wise may as well just buy a program) and just add the newly created (shrink output file) video into TDA and create a menu.
    What We Do In Life, Echoes In Eternity....
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    TDA doesn't support subtitles.
    He's a liar and a murderer, and I say that with all due respect.
  5. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    oh sorry wasn't aware of that
