    Oct 2005
    USA
    What can I use to compress a mpeg2 file in order to fit it on a 4.7 dvd? I have tried Cucusoft Mpeg to Dvd but it doesn't work. The file was captured from TV using an ATI All In Wonder Card. I have trimmed it as much as possible and it is currently at 4.35 gig, but Nero won't work. A friend gave me a program that will compress the files once they are in vob format, but what can I use to larger files into vob format so that I can compress the files. Step by step, if possible.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    You can author the dvd FIRST and then use dvd shrink to shrink it to fit a dvdr (it will create it on the harddrive) THEN you can burn the dvd.
  3. Member rwmol's Avatar
    Feb 2005
    I agree with Yoda.
    Author your Mpeg2 with something like TMPGEnc DVD Author (assuming your file is DVD compliant, if it isn't, I can tell you how to set up your "Personal Video Recorder" from your ATI All In Wonder software)
    Once authored, you can reduce the file size with DVD Shrink then burn with Nero.
    Good luck
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Rejig can transcode MPEG-2 files:
    https://www.videohelp.com/guides.php?guideid=805#805
    Or do as the other guys say and author deliberately oversize, then use a transcoder like DVDShrink or DVD2One to pull it down to size.
    If in doubt, Google it.
    Oct 2005
    USA
    What else can I use to author the file to vob format other than TMPGEnc DVD Author? I keep getting an error message saying that install program for TMPGEnc DVD Author is not a valid win32 application.
