Is there a simple program that allows me to convert my downloaded mpg music videos into a vcd format (I think vcds are DAT files - correct me if I am wrong)
I am trying to play my music videos I download from computer in my dvd player!
thank you so much guys!
[/b]
nero burning rom or nerovision express, select vcd and add the avi,mpg.
or
convert with tmpgenc and author to a vcd with vcdeasy. -
baldrick.
What is the difference between converting from mpg and avi to vcd
as opposed to converting mpg and avi to dvd?
the latter wouldnt give a better picture quality would it? I assume it just give it more storing capacity (nothing on the resolution)
Does nero convert MPG to DVD format? TMPEgc doesnt convert mpg to dvd, only avi to dvd. -
Originally Posted by jyeh74
~320x240/<2000kbps/<60min then make a VCD.
~640x480/>2000kbps/>60min then make a DVD.
*If the source looks bad then the end result will also,increasing the resolution will not improve the picture.
TMPGEnc can only encode AVI/MPEG->MPEG...you need TDA to author.NeroVision Express will encode and author a VCD,SVCD or DVD. -
baldrick or anyone who can answer.
Can I use Nero Burning ROM to select dvd and add my mpg, avi files? I never knew that Nero can do the conversion from mpg to dvd format. I know it can burn mpg onto a dvd-r or dvd+r (data disc), but doing that will NOT allow me to view my burned files on a dvd player on a tv or car.
Will Nero only allow me to convert mpg to vcd format? I hope to convert to dvd so that I can fit more of these 50 mb music video (mpg files) onto a 4.7 gig disc instead!
By the way, what is dvd format? I know vcd is DAT format. Someone said you can probably just change the ".mpg" to ".dat" and burn it without having to convert in nero....dont know if that is true.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
convert DAT TO avi
By skorpinok in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 03:53 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42
