Thanks to some offline testing with mapache I have managed to resolve the neverending menu bug. (it was due to EU locale and the decimal point).
The result is Build: 2.0.2110
It is on the users area. (if the website shows the old version ignore that as i have yet to update the page)
I noticed that you are developing, so, I don't have any problem with leaks. They are expected. Your software does some checks, I get some errors that it can't find "name_S2D.mpg", when I used a mpg passed off a DVD. I can try fixing the mpg, you probably are making decisions on mpg versions. I noticed TMPGENC doesn't do a great job at sync, and after fixing a mpg once with PVAStrumento your choices get worse. I wanted to include my TMPGENC template.
Cut&Paste Save as mfc ?
"DVR Recorded 2560 Khz 72CQ 528X576 Audio 384kbs.mcf"
Could you add a download area ?
I also saw a HEX Value fix for MPG in analysing codecs internal so the App would be fooled looking at the header. (Some apps and playback programs)
I could look that up.
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 17:57 -
New Build -- Please review!
By Deku Scrub in forum ComputerReplies: 17Last Post: 11th Nov 2009, 07:05 -
New PC Build
By faramith in forum ComputerReplies: 37Last Post: 19th Oct 2009, 16:26 -
Computer build up
By lsvtec in forum ComputerReplies: 14Last Post: 6th May 2008, 08:26 -
Memory Help for New Build
By wwaag in forum ComputerReplies: 4Last Post: 2nd Nov 2007, 10:36
