Is it possible to make it so that I can install a new version of S2D I don't have to uninstall the old version first?
Guido
not 100% sure m8 but i think you have to unistall old version befor you can install new version hope this helps ? loopylee
With MSI you don't have to anymore. I sees the old version and uninstalls it before it installs the new version. No I have to it by hand what can be done automaticly.
Originally Posted by guidorobbenSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
FYI here is the thing i read:
http://www.codeproject.com/useritems/msi_upgrade_uninstall.aspSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
As CBC said, uninstall takes only a few seconds as opposed to (what looks to me) a lot of work for CB with no assurance of a complete uninstall. Seems like a support nightmare waiting to happen (just look st the number of dnbxxx posts that could have been resolved by a simple search).
I for one would prefer that CB be able use the time on other aspects of the program.
A manual uninstall just isn't that difficult or time consuming. -
Doesn't matter if it doesn't work. It seems like MS did not do there job. You would think this would be something like setting a checkbox. Lets hop 2005 solves this problem.
Cannot uninstall Nero 9
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2009, 07:31 -
Quicktime wont uninstall/install
By loa909 in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2009, 13:44 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 15:09 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 14:59
