Everytime I hook up a digital camcorder to the firewire card in the pc, MM2 boots up in the capture mode. I do not want to use MM2 for this. I have removed any association with MM2 in the Files Types but MM2 still open when something is connected to the firewire card.
How do I stop this from happening.
Closing it dosent work? Then open whatever Program you want to Transfer.
Sorry Double Post..
If you're comfortable with making Registry changes, this should fix your problem.
In Windows go to Start>Run, type Regedit and click on OK.
Navigate to the following key
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\AutoplayHandlers\UserChosenExec uteHandlers
You should see an entry for your camcorder, mine is -
H:\\?\AVC#Sony&MOD_0&CAMCORDER&DV#2D80700201460008 #{cc7bfb41-f175-11d1-a392-00e0291f3959}\GLOBAL+VideoCameraArrival
but this will vary depending on what camera you have.
Right click on this entry and click Modify. In the dialog box that pops up, type MSPromptEachTime in the Value Data area, then click OK.
Restart Windows.
Now when you attach your camcorder, you should get a prompt to choose a program or action.
Edit:
I found another entry at -
HKEY_USERS\S-1-5-21-3942243025-3757435101-538525854-1005\Software\Microsoft\Windows\CurrentVersion\Exp lorer\AutoplayHandlers\UserChosenExecuteHandlers
which probably covers All users, search for UserChosenExecuteHandlers to change there too."Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Thanks for the help. The Registry change did the trick. I like using ArcSoft Showbiz for capture since it outputs audio as it captures. It was a pain having MM2 open every time I connected a DV device to firewire and having to quit it.
Jay
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 22:19 -
Cannot get trimmed a DV-AVI movie in MS Movie Maker
By askmaxim in forum EditingReplies: 0Last Post: 30th Dec 2008, 05:44 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 10:37 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 22:18
