  1. Ok i am trying to replace a menu cell in vobblanker, i double click on the menu than select it than click replace and replace it with a vob i created with dvdshrink (a still bmp) I than click process on the main movie with the menu and after it processes i run it with vlc media player and the menu is the exact same! Nothing changed. I am looking at this guide however i eliminated alot of it such as using muxman etc because they are telliing you how to create a vob which i already did, can anyone shed some light on this? Thanks
    http://forum.doom9.org/showthread.php?t=99306
  2. Ok i didn't click on preserve menus in vobblanker so i did that and than i imported it into PGC and imported my menu commands and what not, saved it than played it in vlc media player and the main menu comes up which is changed however i cannot click on anything and after a few seconds it plays the regular movie, what did i do wrong?
  3. Ok this is where i am at, after reading the guide again to a T i figured that i didn't have the SUB PIC that is why none of my dvd menu items are highlighting. So i read that i need to extract the subpic, did so with program...subpic did everything right, so i thought, loaded the .SST file with the BMP in the directory, the audio file and the bg image into muxman, made the vob than replaced the menu cell with voblanker, went to PGCedit and readded the color schemes and the hot spot button menu, DONE right? Clicked save and loaded the movie in VLC and no highlighting on the buttons WTF?
  4. Why'd you create 2 threads on the same topic? I gave you an alternative method in the other thread.
  5. accident
