I am trying to back-up my Chappelle's Show Season 2 DVD's. I guess I could save a lot of trouble and just put it on Dual Layer. But what fun would that be.I dont want to shrink the DVD because it would have to be compressed at about 58%. So what I am attempting to do;
1. Use Shrink in Re-Author mode to rip motion menu's and approx 4GB of video. Pick a chapter point to end on. Save to HD.
2. Use VOBEdit to DEMUX streams. Doing both the motion menu and the movie.
3. Use TMPEG to join mv2 movie files into one large mv2 file.
4. Join AC3 movie files.
5. Use DVDAuthorGUI to add chapters and motion menu.
This is where the the problem occurs. I added 15 chapters in DVDAuthorGUI. I run it. During the process an error pops up. Something along the lines of "you cant add a button for chapter 9, only 8 chapters exist." So I double check the chapters and there are 15. Anyone had this problem before? Or have a suggestion as to what I am doing wrong?
Also if you have advice on how to make my process more efficient, feel free to chime in.
Thanks in advance,
Ben
Sounds like something went fubar in the mpeg joining process. DVDAuthor only 'sees' the first half of the mpeg, and therefore, only adds chapters to it.
If these 2 titles are actually part of one whole title from the dvd, i suggest using something like rejig or vob2mpg to keep it all together, rather than using some type of mpeg joining program. -
Liquid,
I used Re-jig to rip/demux the video and menu as you suggested. I then put the mv2 and ac3 in DVDAuthor GUI. Put in chapters and menu. Here is the log so you can see what is happening. Thanks for the help.
VDAuthorGUI 0.997 - 1/2/2005
Send problems with DVDAuthorGUI to liquid_217@hotmail.com
***please wait while the titles are multiplexed.
*multiplexing title: 1.....
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File C:\CAPTURE\Chappelle\Re-Jig\chappelle.m2v looks like an MPEG Video stream.
INFO: [???] File C:\CAPTURE\Chappelle\Re-Jig\chappelle.ac3 looks like an AC3 Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (C:\CAPTURE\Chappelle\Re-Jig\chappelle.m2v)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 720
INFO: [???] Frame height : 480
INFO: [???] Aspect ratio : 4:3 display
INFO: [???] Picture rate : 29.970 frames/sec
INFO: [???] Bit rate : 8500000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: AC3 Audio stream 00 (C:\CAPTURE\Chappelle\Re-Jig\chappelle.ac3)
INFO: [???] AC3 frame size = 768
INFO: [???] AC3 AUDIO STREAM:
INFO: [???] Bit rate : 24576 bytes/sec (192 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 8876096
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio bd: buf= 16384 frame=000000 sector=00000000
INFO: [???] Scanned to end AU 39051
INFO: [???] Scanned to end AU 69455
INFO: [???] Running out...
INFO: [???] Video e0: buf= 2731 frame=069455 sector=00929264
INFO: [???] Audio bd: buf= 1507 frame=072426 sector=00027591
**ERROR: [???] Need to split output but there appears to be no %d in the filename pattern C:\CAPTURE\Chappelle\chap-disc-one\title1.mpg
*generating button images.......
*generating highlight button 1 for menu 1
*generating highlight button 2 for menu 1
*generating highlight button 3 for menu 1
*generating highlight button 4 for menu 1
*generating highlight button 5 for menu 1
*generating select button 1 for menu 1
*generating select button 2 for menu 1
*generating select button 3 for menu 1
*generating select button 4 for menu 1
*generating select button 5 for menu 1
*multiplexing menu 1.....
INFO: [???] File C:\CAPTURE\Chappelle\Re-Jig\menu.m2v looks like an MPEG Video stream.
INFO: [???] File C:\CAPTURE\Chappelle\Re-Jig\menu.ac3 looks like an AC3 Audio stream.
INFO: [???] Scanning for header info: Video stream e0 (C:\CAPTURE\Chappelle\Re-Jig\menu.m2v)
INFO: [???] Bit rate : 9000000 bits/sec
INFO: [???] Scanning for header info: AC3 Audio stream 00 (C:\CAPTURE\Chappelle\Re-Jig\menu.ac3)
INFO: [???] rough-guess multiplexed stream data rate : 9386344
INFO: [???] Scanned to end AU 1510
INFO: [???] Scanned to end AU 2615
INFO: [???] STREAM e0 completed @ frame 2615.
INFO: [???] STREAM bd completed @ frame 2725.
INFO: [???] Multiplex completion at SCR=7809462.
INFO: [???] Video e0: buf= 153485 frame=002615 sector=00031596
INFO: [???] Audio bd: buf= 1792 frame=002725 sector=00001039
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 63813129 bytes
INFO: [???] Sequence headers: 175
INFO: [???] Sequence ends : 2
INFO: [???] No. Pictures : 2615
INFO: [???] No. Groups : 175
INFO: [???] No. I Frames : 175 avg. size 96327 bytes
INFO: [???] No. P Frames : 871 avg. size 25526 bytes
INFO: [???] No. B Frames : 1571 avg. size 15736 bytes
INFO: [???] Average bit-rate : 5846400 bits/sec
INFO: [???] Peak bit-rate : 7712400 bits/sec
INFO: [???] BUFFERING min 15 Buf max 134306
INFO: [???] AUDIO_STATISTICS: bd
INFO: [???] Audio stream length 2093568 bytes.
INFO: [???] Frames : 16779942
INFO: [???] BUFFERING min 67 Buf max 4483
INFO: [???] MUX STATUS: no under-runs detected.
DVDAuthor:
pumux, version 0.6.10-2773.
Build options: gnugetopt iconv freetype
Send bugs to <dvdauthor-users@lists.sourceforge.net>
INFO: Locale=C
INFO: Converting filenames to US-ASCII
STAT: 0:00:00.000
INFO: PNG had 2 colors
INFO: Constructing blank img
INFO: Pickbuttongroups, success with 1 groups, useimg=1
INFO: Found EOF in .sub file.
INFO: Max_sub_size=562
WARN: Read 0, expected 4
INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
Statistics:
- Processed 0 subtitles.
- The longest display line had -1 characters.
- The maximum number of displayed lines was 0.
- The normal display height of the font arial.ttf was 0.
- The bottom display height of the font arial.ttf was 0.
- The biggest subtitle box had 562 bytes.
erase "C:\CAPTURE\Chappelle\chap-disc-one\menu1.mpg"
echo *authoring title(s).....
"C:\Program Files\DVDAuthorGUI\bin\dvdauthor.exe" -x "C:\Program Files\DVDAuthorGUI\config.xml"
DVDAuthor::dvdauthor, version 0.6.10-2773.
INFO: Locale=C
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing C:\CAPTURE\Chappelle\chap-disc-one\menusub1.mpg...
STAT: VOBU 16 at 4MB, 1 PGCS
STAT: VOBU 32 at 10MB, 1 PGCS
STAT: VOBU 48 at 16MB, 1 PGCS
STAT: VOBU 64 at 23MB, 1 PGCS
STAT: VOBU 80 at 29MB, 1 PGCS
STAT: VOBU 96 at 34MB, 1 PGCS
STAT: VOBU 112 at 41MB, 1 PGCS
STAT: VOBU 128 at 47MB, 1 PGCS
STAT: VOBU 144 at 53MB, 1 PGCS
STAT: VOBU 160 at 59MB, 1 PGCS
INFO: Video pts = 0.178 .. 87.465
INFO: Audio[0] pts = 0.178 .. 87.410
INFO: Audio[32] pts = 0.178 .. 0.178
STAT: VOBU 172 at 64MB, 1 PGCS
INFO: Generating VTSM with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: ntsc
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
INFO: Audio ch 0 format: ac3/2ch, 48khz drc
STAT: Processing C:\CAPTURE\Chappelle\chap-disc-one\title1.mpg...
STAT: VOBU 32 at 8MB, 1 PGCS
STAT: VOBU 48 at 12MB, 1 PGCS
STAT: VOBU 64 at 18MB, 1 PGCS
STAT: VOBU 80 at 23MB, 1 PGCS
STAT: VOBU 96 at 28MB, 1 PGCS
STAT: VOBU 112 at 34MB, 1 PGCS
STAT: VOBU 128 at 40MB, 1 PGCS
STAT: VOBU 144 at 45MB, 1 PGCS
STAT: VOBU 160 at 51MB, 1 PGCS
STAT: VOBU 176 at 56MB, 1 PGCS
STAT: VOBU 192 at 62MB, 1 PGCS
STAT: VOBU 208 at 67MB, 1 PGCS
STAT: VOBU 224 at 73MB, 1 PGCS
STAT: VOBU 240 at 80MB, 1 PGCS
STAT: VOBU 256 at 87MB, 1 PGCS
STAT: VOBU 272 at 93MB, 1 PGCS
STAT: VOBU 288 at 99MB, 1 PGCS
STAT: VOBU 304 at 105MB, 1 PGCS
STAT: VOBU 320 at 111MB, 1 PGCS
STAT: VOBU 336 at 116MB, 1 PGCS
STAT: VOBU 352 at 122MB, 1 PGCS
STAT: VOBU 368 at 128MB, 1 PGCS
STAT: VOBU 384 at 134MB, 1 PGCS
STAT: VOBU 400 at 140MB, 1 PGCS
STAT: VOBU 416 at 146MB, 1 PGCS
STAT: VOBU 432 at 152MB, 1 PGCS
STAT: VOBU 448 at 158MB, 1 PGCS
STAT: VOBU 464 at 163MB, 1 PGCS
STAT: VOBU 480 at 169MB, 1 PGCS
STAT: VOBU 496 at 175MB, 1 PGCS
STAT: VOBU 512 at 181MB, 1 PGCS
STAT: VOBU 528 at 188MB, 1 PGCS
STAT: VOBU 544 at 194MB, 1 PGCS
STAT: VOBU 560 at 200MB, 1 PGCS
STAT: VOBU 576 at 206MB, 1 PGCS
STAT: VOBU 592 at 212MB, 1 PGCS
STAT: VOBU 608 at 219MB, 1 PGCS
STAT: VOBU 624 at 225MB, 1 PGCS
STAT: VOBU 640 at 230MB, 1 PGCS
STAT: VOBU 656 at 237MB, 1 PGCS
STAT: VOBU 672 at 243MB, 1 PGCS
STAT: VOBU 688 at 249MB, 1 PGCS
STAT: VOBU 704 at 255MB, 1 PGCS
STAT: VOBU 720 at 260MB, 1 PGCS
STAT: VOBU 736 at 266MB, 1 PGCS
STAT: VOBU 752 at 272MB, 1 PGCS
STAT: VOBU 768 at 277MB, 1 PGCS
STAT: VOBU 784 at 283MB, 1 PGCS
STAT: VOBU 800 at 289MB, 1 PGCS
STAT: VOBU 816 at 295MB, 1 PGCS
STAT: VOBU 832 at 300MB, 1 PGCS
STAT: VOBU 848 at 306MB, 1 PGCS
STAT: VOBU 864 at 312MB, 1 PGCS
STAT: VOBU 880 at 317MB, 1 PGCS
STAT: VOBU 896 at 323MB, 1 PGCS
STAT: VOBU 912 at 330MB, 1 PGCS
STAT: VOBU 928 at 336MB, 1 PGCS
STAT: VOBU 944 at 342MB, 1 PGCS
STAT: VOBU 960 at 348MB, 1 PGCS
STAT: VOBU 976 at 354MB, 1 PGCS
STAT: VOBU 992 at 360MB, 1 PGCS
STAT: VOBU 1008 at 366MB, 1 PGCS
STAT: VOBU 1024 at 372MB, 1 PGCS
STAT: VOBU 1040 at 378MB, 1 PGCS
STAT: VOBU 1056 at 383MB, 1 PGCS
STAT: VOBU 1072 at 388MB, 1 PGCS
STAT: VOBU 1088 at 394MB, 1 PGCS
STAT: VOBU 1104 at 399MB, 1 PGCS
STAT: VOBU 1120 at 404MB, 1 PGCS
STAT: VOBU 1136 at 410MB, 1 PGCS
STAT: VOBU 1152 at 415MB, 1 PGCS
STAT: VOBU 1168 at 421MB, 1 PGCS
STAT: VOBU 1184 at 426MB, 1 PGCS
STAT: VOBU 1200 at 431MB, 1 PGCS
STAT: VOBU 1216 at 437MB, 1 PGCS
STAT: VOBU 1232 at 443MB, 1 PGCS
STAT: VOBU 1248 at 449MB, 1 PGCS
STAT: VOBU 1264 at 455MB, 1 PGCS
STAT: VOBU 1280 at 461MB, 1 PGCS
STAT: VOBU 1296 at 467MB, 1 PGCS
STAT: VOBU 1312 at 473MB, 1 PGCS
STAT: VOBU 1328 at 479MB, 1 PGCS
STAT: VOBU 1344 at 485MB, 1 PGCS
STAT: VOBU 1360 at 491MB, 1 PGCS
STAT: VOBU 1376 at 496MB, 1 PGCS
STAT: VOBU 1392 at 502MB, 1 PGCS
STAT: VOBU 1408 at 508MB, 1 PGCS
STAT: VOBU 1424 at 514MB, 1 PGCS
STAT: VOBU 1440 at 519MB, 1 PGCS
STAT: VOBU 1456 at 525MB, 1 PGCS
STAT: VOBU 1472 at 530MB, 1 PGCS
STAT: VOBU 1488 at 536MB, 1 PGCS
STAT: VOBU 1504 at 542MB, 1 PGCS
STAT: VOBU 1520 at 548MB, 1 PGCS
STAT: VOBU 1536 at 553MB, 1 PGCS
STAT: VOBU 1552 at 560MB, 1 PGCS
STAT: VOBU 1568 at 566MB, 1 PGCS
STAT: VOBU 1584 at 571MB, 1 PGCS
STAT: VOBU 1600 at 577MB, 1 PGCS
STAT: VOBU 1616 at 582MB, 1 PGCS
STAT: VOBU 1632 at 587MB, 1 PGCS
STAT: VOBU 1648 at 593MB, 1 PGCS
STAT: VOBU 1664 at 600MB, 1 PGCS
STAT: VOBU 1680 at 606MB, 1 PGCS
STAT: VOBU 1696 at 612MB, 1 PGCS
STAT: VOBU 1712 at 618MB, 1 PGCS
STAT: VOBU 1728 at 624MB, 1 PGCS
STAT: VOBU 1744 at 630MB, 1 PGCS
STAT: VOBU 1760 at 636MB, 1 PGCS
STAT: VOBU 1776 at 642MB, 1 PGCS
STAT: VOBU 1792 at 649MB, 1 PGCS
STAT: VOBU 1808 at 655MB, 1 PGCS
STAT: VOBU 1824 at 661MB, 1 PGCS
STAT: VOBU 1840 at 668MB, 1 PGCS
STAT: VOBU 1856 at 674MB, 1 PGCS
STAT: VOBU 1872 at 680MB, 1 PGCS
STAT: VOBU 1888 at 686MB, 1 PGCS
STAT: VOBU 1904 at 692MB, 1 PGCS
STAT: VOBU 1920 at 698MB, 1 PGCS
STAT: VOBU 1936 at 704MB, 1 PGCS
STAT: VOBU 1952 at 709MB, 1 PGCS
STAT: VOBU 1968 at 714MB, 1 PGCS
STAT: VOBU 1984 at 720MB, 1 PGCS
STAT: VOBU 2000 at 726MB, 1 PGCS
STAT: VOBU 2016 at 731MB, 1 PGCS
STAT: VOBU 2032 at 736MB, 1 PGCS
STAT: VOBU 2048 at 741MB, 1 PGCS
STAT: VOBU 2064 at 746MB, 1 PGCS
STAT: VOBU 2080 at 751MB, 1 PGCS
STAT: VOBU 2096 at 757MB, 1 PGCS
STAT: VOBU 2112 at 762MB, 1 PGCS
STAT: VOBU 2128 at 767MB, 1 PGCS
STAT: VOBU 2144 at 772MB, 1 PGCS
STAT: VOBU 2160 at 777MB, 1 PGCS
STAT: VOBU 2176 at 782MB, 1 PGCS
STAT: VOBU 2192 at 787MB, 1 PGCS
STAT: VOBU 2208 at 792MB, 1 PGCS
STAT: VOBU 2224 at 797MB, 1 PGCS
STAT: VOBU 2240 at 802MB, 1 PGCS
STAT: VOBU 2256 at 807MB, 1 PGCS
STAT: VOBU 2272 at 812MB, 1 PGCS
STAT: VOBU 2288 at 817MB, 1 PGCS
STAT: VOBU 2304 at 823MB, 1 PGCS
STAT: VOBU 2320 at 828MB, 1 PGCS
STAT: VOBU 2336 at 833MB, 1 PGCS
STAT: VOBU 2352 at 838MB, 1 PGCS
STAT: VOBU 2368 at 843MB, 1 PGCS
STAT: VOBU 2384 at 849MB, 1 PGCS
STAT: VOBU 2400 at 854MB, 1 PGCS
STAT: VOBU 2416 at 859MB, 1 PGCS
STAT: VOBU 2432 at 864MB, 1 PGCS
STAT: VOBU 2448 at 870MB, 1 PGCS
STAT: VOBU 2464 at 875MB, 1 PGCS
STAT: VOBU 2480 at 880MB, 1 PGCS
STAT: VOBU 2496 at 886MB, 1 PGCS
STAT: VOBU 2512 at 891MB, 1 PGCS
STAT: VOBU 2528 at 896MB, 1 PGCS
STAT: VOBU 2544 at 902MB, 1 PGCS
STAT: VOBU 2560 at 907MB, 1 PGCS
STAT: VOBU 2576 at 913MB, 1 PGCS
STAT: VOBU 2592 at 918MB, 1 PGCS
STAT: VOBU 2608 at 923MB, 1 PGCS
STAT: VOBU 2624 at 928MB, 1 PGCS
STAT: VOBU 2640 at 934MB, 1 PGCS
STAT: VOBU 2656 at 939MB, 1 PGCS
STAT: VOBU 2672 at 944MB, 1 PGCS
STAT: VOBU 2688 at 949MB, 1 PGCS
STAT: VOBU 2704 at 955MB, 1 PGCS
STAT: VOBU 2720 at 960MB, 1 PGCS
STAT: VOBU 2736 at 965MB, 1 PGCS
STAT: VOBU 2752 at 970MB, 1 PGCS
STAT: VOBU 2768 at 975MB, 1 PGCS
STAT: VOBU 2784 at 981MB, 1 PGCS
STAT: VOBU 2800 at 986MB, 1 PGCS
STAT: VOBU 2816 at 992MB, 1 PGCS
STAT: VOBU 2832 at 998MB, 1 PGCS
STAT: VOBU 2848 at 1004MB, 1 PGCS
STAT: VOBU 2864 at 1010MB, 1 PGCS
STAT: VOBU 2880 at 1016MB, 1 PGCS
STAT: VOBU 2896 at 1023MB, 1 PGCS
STAT: VOBU 2912 at 1029MB, 1 PGCS
STAT: VOBU 2928 at 1035MB, 1 PGCS
STAT: VOBU 2944 at 1039MB, 1 PGCS
STAT: VOBU 2960 at 1044MB, 1 PGCS
STAT: VOBU 2976 at 1048MB, 1 PGCS
STAT: VOBU 2992 at 1053MB, 1 PGCS
STAT: VOBU 3008 at 1058MB, 1 PGCS
STAT: VOBU 3024 at 1061MB, 1 PGCS
STAT: VOBU 3040 at 1065MB, 1 PGCS
STAT: VOBU 3056 at 1070MB, 1 PGCS
STAT: VOBU 3072 at 1077MB, 1 PGCS
STAT: VOBU 3088 at 1083MB, 1 PGCS
STAT: VOBU 3104 at 1089MB, 1 PGCS
STAT: VOBU 3120 at 1095MB, 1 PGCS
STAT: VOBU 3136 at 1101MB, 1 PGCS
STAT: VOBU 3152 at 1107MB, 1 PGCS
STAT: VOBU 3168 at 1113MB, 1 PGCS
STAT: VOBU 3184 at 1118MB, 1 PGCS
STAT: VOBU 3200 at 1125MB, 1 PGCS
STAT: VOBU 3216 at 1132MB, 1 PGCS
STAT: VOBU 3232 at 1138MB, 1 PGCS
STAT: VOBU 3248 at 1144MB, 1 PGCS
STAT: VOBU 3264 at 1150MB, 1 PGCS
STAT: VOBU 3280 at 1155MB, 1 PGCS
STAT: VOBU 3296 at 1161MB, 1 PGCS
STAT: VOBU 3312 at 1168MB, 1 PGCS
STAT: VOBU 3328 at 1175MB, 1 PGCS
STAT: VOBU 3344 at 1181MB, 1 PGCS
STAT: VOBU 3360 at 1188MB, 1 PGCS
STAT: VOBU 3376 at 1195MB, 1 PGCS
STAT: VOBU 3392 at 1201MB, 1 PGCS
STAT: VOBU 3408 at 1204MB, 1 PGCS
STAT: VOBU 3424 at 1209MB, 1 PGCS
STAT: VOBU 3440 at 1216MB, 1 PGCS
STAT: VOBU 3456 at 1221MB, 1 PGCS
STAT: VOBU 3472 at 1227MB, 1 PGCS
STAT: VOBU 3488 at 1233MB, 1 PGCS
STAT: VOBU 3504 at 1239MB, 1 PGCS
STAT: VOBU 3520 at 1245MB, 1 PGCS
STAT: VOBU 3536 at 1250MB, 1 PGCS
STAT: VOBU 3552 at 1256MB, 1 PGCS
STAT: VOBU 3568 at 1262MB, 1 PGCS
STAT: VOBU 3584 at 1268MB, 1 PGCS
STAT: VOBU 3600 at 1274MB, 1 PGCS
STAT: VOBU 3616 at 1279MB, 1 PGCS
STAT: VOBU 3632 at 1285MB, 1 PGCS
STAT: VOBU 3648 at 1290MB, 1 PGCS
STAT: VOBU 3664 at 1295MB, 1 PGCS
STAT: VOBU 3680 at 1301MB, 1 PGCS
STAT: VOBU 3696 at 1305MB, 1 PGCS
STAT: VOBU 3712 at 1312MB, 1 PGCS
STAT: VOBU 3728 at 1317MB, 1 PGCS
STAT: VOBU 3744 at 1324MB, 1 PGCS
STAT: VOBU 3760 at 1330MB, 1 PGCS
STAT: VOBU 3776 at 1337MB, 1 PGCS
STAT: VOBU 3792 at 1343MB, 1 PGCS
STAT: VOBU 3808 at 1349MB, 1 PGCS
STAT: VOBU 3824 at 1355MB, 1 PGCS
STAT: VOBU 3840 at 1359MB, 1 PGCS
STAT: VOBU 3856 at 1364MB, 1 PGCS
STAT: VOBU 3872 at 1369MB, 1 PGCS
STAT: VOBU 3888 at 1375MB, 1 PGCS
STAT: VOBU 3904 at 1380MB, 1 PGCS
STAT: VOBU 3920 at 1386MB, 1 PGCS
STAT: VOBU 3936 at 1391MB, 1 PGCS
STAT: VOBU 3952 at 1396MB, 1 PGCS
STAT: VOBU 3968 at 1402MB, 1 PGCS
STAT: VOBU 3984 at 1407MB, 1 PGCS
STAT: VOBU 4000 at 1413MB, 1 PGCS
STAT: VOBU 4016 at 1418MB, 1 PGCS
STAT: VOBU 4032 at 1424MB, 1 PGCS
STAT: VOBU 4048 at 1429MB, 1 PGCS
STAT: VOBU 4064 at 1435MB, 1 PGCS
STAT: VOBU 4080 at 1440MB, 1 PGCS
STAT: VOBU 4096 at 1446MB, 1 PGCS
STAT: VOBU 4112 at 1451MB, 1 PGCS
STAT: VOBU 4128 at 1458MB, 1 PGCS
STAT: VOBU 4144 at 1463MB, 1 PGCS
STAT: VOBU 4160 at 1469MB, 1 PGCS
STAT: VOBU 4176 at 1475MB, 1 PGCS
STAT: VOBU 4192 at 1481MB, 1 PGCS
STAT: VOBU 4208 at 1487MB, 1 PGCS
STAT: VOBU 4224 at 1493MB, 1 PGCS
STAT: VOBU 4240 at 1499MB, 1 PGCS
STAT: VOBU 4256 at 1505MB, 1 PGCS
STAT: VOBU 4272 at 1511MB, 1 PGCS
STAT: VOBU 4288 at 1516MB, 1 PGCS
STAT: VOBU 4304 at 1522MB, 1 PGCS
STAT: VOBU 4320 at 1528MB, 1 PGCS
STAT: VOBU 4336 at 1534MB, 1 PGCS
STAT: VOBU 4352 at 1540MB, 1 PGCS
STAT: VOBU 4368 at 1546MB, 1 PGCS
STAT: VOBU 4384 at 1551MB, 1 PGCS
STAT: VOBU 4400 at 1557MB, 1 PGCS
STAT: VOBU 4416 at 1564MB, 1 PGCS
STAT: VOBU 4432 at 1569MB, 1 PGCS
STAT: VOBU 4448 at 1575MB, 1 PGCS
STAT: VOBU 4464 at 1581MB, 1 PGCS
STAT: VOBU 4480 at 1587MB, 1 PGCS
STAT: VOBU 4496 at 1593MB, 1 PGCS
STAT: VOBU 4512 at 1599MB, 1 PGCS
STAT: VOBU 4528 at 1606MB, 1 PGCS
STAT: VOBU 4544 at 1612MB, 1 PGCS
STAT: VOBU 4560 at 1618MB, 1 PGCS
STAT: VOBU 4576 at 1624MB, 1 PGCS
STAT: VOBU 4592 at 1630MB, 1 PGCS
STAT: VOBU 4608 at 1636MB, 1 PGCS
STAT: VOBU 4624 at 1642MB, 1 PGCS
STAT: VOBU 4640 at 1648MB, 1 PGCS
STAT: VOBU 4656 at 1653MB, 1 PGCS
STAT: VOBU 4672 at 1659MB, 1 PGCS
STAT: VOBU 4688 at 1664MB, 1 PGCS
STAT: VOBU 4704 at 1669MB, 1 PGCS
STAT: VOBU 4720 at 1674MB, 1 PGCS
STAT: VOBU 4736 at 1680MB, 1 PGCS
STAT: VOBU 4752 at 1685MB, 1 PGCS
STAT: VOBU 4768 at 1691MB, 1 PGCS
STAT: VOBU 4784 at 1696MB, 1 PGCS
STAT: VOBU 4800 at 1701MB, 1 PGCS
STAT: VOBU 4816 at 1707MB, 1 PGCS
STAT: VOBU 4832 at 1712MB, 1 PGCS
STAT: VOBU 4848 at 1717MB, 1 PGCS
STAT: VOBU 4864 at 1723MB, 1 PGCS
STAT: VOBU 4880 at 1728MB, 1 PGCS
STAT: VOBU 4896 at 1733MB, 1 PGCS
STAT: VOBU 4912 at 1738MB, 1 PGCS
STAT: VOBU 4928 at 1743MB, 1 PGCS
STAT: VOBU 4944 at 1749MB, 1 PGCS
STAT: VOBU 4960 at 1754MB, 1 PGCS
STAT: VOBU 4976 at 1759MB, 1 PGCS
STAT: VOBU 4992 at 1765MB, 1 PGCS
STAT: VOBU 5008 at 1770MB, 1 PGCS
STAT: VOBU 5024 at 1775MB, 1 PGCS
STAT: VOBU 5040 at 1780MB, 1 PGCS
STAT: VOBU 5056 at 1785MB, 1 PGCS
STAT: VOBU 5072 at 1790MB, 1 PGCS
STAT: VOBU 5088 at 1795MB, 1 PGCS
STAT: VOBU 5104 at 1800MB, 1 PGCS
STAT: VOBU 5120 at 1805MB, 1 PGCS
STAT: VOBU 5136 at 1810MB, 1 PGCS
STAT: VOBU 5152 at 1815MB, 1 PGCS
STAT: VOBU 5168 at 1820MB, 1 PGCS
STAT: VOBU 5184 at 1825MB, 1 PGCS
STAT: VOBU 5200 at 1830MB, 1 PGCS
STAT: VOBU 5216 at 1836MB, 1 PGCS
STAT: VOBU 5232 at 1841MB, 1 PGCS
STAT: VOBU 5248 at 1847MB, 1 PGCS
STAT: VOBU 5264 at 1852MB, 1 PGCS
STAT: VOBU 5280 at 1857MB, 1 PGCS
STAT: VOBU 5296 at 1862MB, 1 PGCS
STAT: VOBU 5312 at 1867MB, 1 PGCS
STAT: VOBU 5328 at 1872MB, 1 PGCS
STAT: VOBU 5344 at 1877MB, 1 PGCS
INFO: Video pts = 0.178 .. 2317.693
INFO: Audio[0] pts = 0.178 .. 2317.842
STAT: VOBU 5349 at 1879MB, 1 PGCS
INFO: Generating VTS with the following video attributes:
ERR: Cannot jump to chapter 12 of title 1, only 8 exist
ERR: in VTSM pgc 0, button 5 erase "C:\CAPTURE\Chappelle\chap-disc-one\*.mpg"
echo *process complete
*process complete -
use restream to remove the end of stream markers. Also, you may want to update the gui, as there are many bugfixes since 0.997.
refer to here: https://www.videohelp.com/forum/viewtopic.php?t=241820&highlight=restream+dvdauthorgui -
Liquid,
Thanks for the help. That got the problem fixed. Another quick question and I think I will be good to go. If I rip/demux a few chapters from different DVD's, what program would you suggest to join the mv2 files? Thanks, again. -
I don't suggest joining m2v files at all. Most of the time, it least to sync trouble, and other problems. As long as their attributes are the same, just load them in as separate titles.
DVDAuthorGUI - Question about spu begin/end
By ilmc92 in forum Authoring (DVD)Replies: 2Last Post: 10th Dec 2011, 06:37 -
dvdauthorgui menu question/problem
By tacitus in forum Authoring (DVD)Replies: 7Last Post: 11th Oct 2011, 21:53 -
DVDAuthorGUI Problem...
By beckmen in forum Authoring (DVD)Replies: 12Last Post: 1st Jul 2010, 12:34 -
DVDauthorGUI question
By AlecWest in forum Authoring (DVD)Replies: 2Last Post: 20th May 2008, 12:46 -
DVDauthorGUI question regarding subtitles
By AlecWest in forum Authoring (DVD)Replies: 6Last Post: 6th Dec 2007, 15:05
