I tring to rip my AC/DC dvd & im getting this W 07:43:55 Possible Structure Protection Found!
W 07:43:55 1 area has been marked as 'suspect'.
W 07:43:55 Dummy sectors will be inserted where necessary.
Nero says _ DVD-Video files reallocation failed too.
Also Shrink had a Fail also, it's a new disc, anyone know what might be going on with it? Thanks
Are you using the very latest version of DVD Decrypter?
A quick search on Google also revealed another user having the same issue as yourself:
http://forums.afterdawn.com/thread_view.cfm/239426
Hope this helps!
Cobra -
Try DVDFab Decrypter, it can handle the latest protections.
Which AC-DC dvd is it & what region ?
I was just wondering as i did "Family Jewels" about a month ago. -
most time does not matter; the disc will still play on a set-top or PC. but the menu might not work properly on a set-top. I just backed up a number of discs that Nero reported as above, and all plays properly on my PC (menus too) but will lock up on my set-top if I access the menu. luckily I set the dvdr navigation to play the movie when dvdr is inserted instead of going directly to the menu as on the original.Nero says _ DVD-Video files reallocation failed too
noki
I just don't want no lock-ups & wasted dvd's, and NO pop-up errors at all before a burn if I can. So im just asking. Thanks.
Noahtuck
Which AC-DC dvd is it & what dvd region ?
It's the Live At Donington, Player Information:
Player Region Code: Not Specified
Current Drive: E:
Title Region Code: Not Available
trailers and warnings tool to eliminate and end user friendly
By vanc in forum DVD RippingReplies: 20Last Post: 7th Nov 2010, 11:08 -
Test warnings
By alfresco in forum TestReplies: 3Last Post: 1st Feb 2010, 05:35 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 13:48 -
Are there any players/firmware hacks to allow skipping of warnings/preview?
By Sephiroth666 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 14th Mar 2008, 07:37 -
Laser printer warnings?
By Bartron in forum ComputerReplies: 8Last Post: 8th May 2007, 12:07
